divider synthesize error
PRAVEEN HV
Junior Member level 2
BELAGAVI
I've attached division code, simulation result is correct but while synthesizing i'm getting following error..
plz anybody fix this error...????
thank u..
"ERROR:Xst:2587 Port <port_name> of instance <inst_name> has different type in definition <def_name>"
  • div_comb_r4_arch2.rar
hi sir i'm getting following errors..
ERROR:Xst:2587 - Port <new_r> of instance <g1[0].cell> has different type in definition <nr_r4_half_cell>.
ERROR:Xst:2587 - Port <op_3y> of instance <g1[0].cell> has different type in definition <nr_r4_half_cell>.
ERROR:Xst:2587 - Port <op_r> of instance <g1[0].cell> has different type in definition <nr_r4_half_cell>.
ERROR:Xst:2587 - Port <op_y> of instance <g1[0].cell> has different type in definition <nr_r4_half_cell>.
Is it a guessing game? You surely can tell for which line of source and line of code the error is reported! Otherwise start to learn your tools.
---------- Post added at 15:56 ---------- Previous post was at 15:44 ----------
Seems to be a problem of your tool chain. It's correct VHDL as far as I see.
It is not showing the line of error.. Insted i'm getting as below.. plz help me..
---------- Post added at 19:34 ---------- Previous post was at 19:30 ----------
ok thank u sir
i'll check it..
