display 2digit number in 7-segment
mahshid_2011
Newbie level 5
Hello
i want to add two number that two number is bigger than 20 and I want to display that in the seven segment with proteuse software
my problem is i cant show 2 digit number in seven segment you can help me ?
I dont want to programming !
my professer want to design this circuit with proteuse software and without code and programing
in this picture I can add to 1digit and show 1digit number in seven segment
now i want to display two digit number in 7-segment**broken link removed**
this could be the configuration. the displays are common anode type. for Proteus they run but when in reality you may need pnp transistor buffers for the common anode drive.
the oscillator using Gate A should be around 25HZ or Higher. the R and C values have to be chosen accordingly.
  • 2digit display.pdf
perhaps it is a Homework on digital logic gates and counters /decoders. the O P clearly stated that he/she has to tdo without code or programming.
you should search for bcd to seven seg decoder IC and interface it to seven seg display then.
Just tie the carry bit to the least significant bit of the decoder and ground all the other input bits.
hi grieblm
I drew the circuit that you say As follows on file attachment
but it doesn't answer and for example it doesn't display 20+20
is the my circuit correct??
