0000 = ECCP OFF
Klaus
Code C - [expand] 1 2 3 CCPxM<3:0> = 0000 //Capture/Compare/PWM off (resets the module)
Absolutely they can. The register descriptions show each of the 8 bits and the port pins they correspond to. Therefore you can use any of the various ways of setting and clearing the bits individually to set the ports up as you need to.It is not mentioned for rest of ports i,e PORTC and PORTBcan these other pins be configured individually input/output or not?
