redreobingarden
Newbie level 3
Hello! We are working on a product that has some wires directly soldered to a PCB. These are internal wires that never move and we have decided that we can save costs by omitting connectors.
I was wondering if there are any best practices on this. At this point I'm aware of only two ways of doing this:
1. Plated thru-hole on the PCB. Stripped+tinned wire goes in plated thru-hole, solder+soldering iron applied to make the joint.
2. Sufficiently large pad on PCB that can be covered in a layer of solder from either a wave-soldering or re-flow process. Operator then just has to place a stripped and tinned wire on the pre-soldered pad and hit it with a soldering iron.
It seems that if there is space available on the PCB, number 2 is the best option? Are there any other options that you guys have had experience with? Thanks!
