dipole antenna design in freq range of 0.7-3ghz
rajkumar3886
Newbie level 5
I started desining with dipole antenna in freq range of 0.7-3ghz ..I need suggestions and papers for desired freq range..plz help me out..!!!!
kommanche
Member level 4
It depends on your specifications but most practical way is to design it at 1.85 GHz as lambda/4. For larger bandwidth you may design log periodic dipole.
rajkumar3886
Newbie level 5
Im using ads software and the substrate is RO4360...
kommanche
Member level 4
I suggest you to use CST or HFSS for antenna design
varuniyengar
ADS is ok but the adjustments with radiation patterns, gain analysis in not advised on ADS.
