ali_cmi
Junior Member level 2
Hello!
I was given a task to optimize a contiguous LPF-HPF suspended-substrate diplexer (doubly-terminated filters). The modelling was done in HFSS. I re-shaped/designed the model to make it almost fully relative, that is, it accepts the variations of length and width in one of the filter elements.
The problem is, when I try to optimize it, all four optimization algorithms of HFSS just don't reduce the Error-Factor (EF) below 100. But when I do it myself, the EF reduces to around 28 and the response is still not-acceptable. There are 7 variables in total which control the pole-positions of LPF (2-3 poles) and HPF (4 poles) and I don't understand there relation effectively. When one of the filters responds as it should, the other one's totally messed up.
View attachment dip_208G_fab_test_12_LPF_HPF_combined_10_start-8_HPF_mods_16.rar
As a susceptance-annulling stub, a physical screw is being simulated in HFSS: changing its height at the tee-junction cancels the imaginary part of impedance.
Kindly guide me to a better understanding of such diplexers by sharing some design information/material/data. Attached is my design. Take a look at it.
Waiting for your response.
Muhammad Ali
Muhammad Ali
