Digital Voltmeter design on FPGA.
kohtet
Who can help me to do digital voltmeter on FPGA. I want to know which are the essential steps when i achieve to do my topic. I am also new about FPGA. Thank u !
is it enough to complete. Do u have any example file or code for this topic?
No.
No.
But once you know how to describe digital logic with HDL you'll be able to proceed with your task.
Then you'll need an ADC circuit with a digital output (I2C/SPI etc...) that's capable of positive and negative inputs (in the limits you want to measure) and an LCD screen to show the results.
No I don't.
This may help you.
yes. it is. The pdf file for digital voltmeter with code, diagram, and testing. It's will be ok.
Did you look at the VHDL code? Scary.
A common question of beginner digital engineers: "what projects are better to implement on a uC and what on FPGAs?"
I think that a "digital multimeter" is a very good example for a project that will be MUCH easier (and cheaper) to do on a uC and not on an FPGA.
Kohtet.
With that said, if it's for learning purposes only - I encourage you to try and implement your design in Verilog/VHDL. You'll gain a lot of valuable knowledge/experience.
Just as scary is the use of PNP in reverse polarity
Now, i start doing on VHDL coding. This is my final year project. I think it has long time to study. Unfortunately, my university ask me to show the simulation on 3rd week of September. So, i am in trouble. That's why. The point is i have to do as fast as possible to code for Digital voltmeter on FPGA. Thank U guy. !! I appreciate all of your advices. THANK again. :D have a good day.
