Digital oscilloscope Project
oscilloscope front end design
Make_Pic said:
nikifena said:
You think - everyone are able to read in Russian?
I will translate. It is pretty simple and cheap (35$) device based on new C8051F321 from SiLabs. It uses on-chip features like USB and memory to store and transfer samples, and external ADC. Features include logic analyzer (2.7 Mhz), oscillograph (200 kHz), logic generator (1.7 Mhz) and some others mode. Some additional features like signal filtration, protocol analysing (I2C, SPI, 1-Wire, UART) and firmware updates are available via PC GUI.
The scheme is here: http://www.usb-osc.narod.ru/files/shem.png
Firmware: http://www.usb-osc.narod.ru/dw_hex.htm
GUI + driver: http://www.usb-osc.narod.ru/dw_soft.htm
Pictures: http://www.usb-osc.narod.ru/foto.htm
GUI screenshots:
http://www.usb-osc.narod.ru/osc.htm
http://www.usb-osc.narod.ru/flt.htm
http://www.usb-osc.narod.ru/fft.htm
http://www.usb-osc.narod.ru/uart.htm
http://www.usb-osc.narod.ru/lan.htm
http://www.usb-osc.narod.ru/patch.htm
oscilloscope fpga schematic
Is there any personal site on internet about an osc. project ?
pc based oscilloscope circuits
Why do you post a website which contains only a title???
rangkaian digital oscilloscope
If anyone is still monitoring this topic there is a yahoo group that is working on developing a scope/analyzer maybe folks can join forces with them
search for multianalyzer
Thanks
Jay
nais photomos uses
PC-based DSO
ads831e dso
nbn said:
PC-based DSO
h**p://a26.lambo.student.liu.se/?section=hard&project=scope
It is only gallery with pictures! :(
dso fifo
nbn said:
PC-based DSO
I wonder what happened to that project? The last entry is dated 27.04.2004. and right at the moment the guy seemed to come to the working solution.
Does anybody have any news on that one?
digital ocsilloscope
nbn said:
PC-based DSO
That's my site (hi everyone!).
I was to busy with other things for several months, but recently I've started work on the DSO project again. Also on some other projects and a new website (which is why I haven't updated the old one at all).
I just gave the URL for the new site (not actually ready yet) to "lighty", so I guess I might as well post it here as well.
There is some new info there, but not a lot (yet).
Now I really have to go study, but I will do a lot more soldering and programming after my exams :)
gbdso-gameboy-digital-sampling-oscilloscope
@cyr
Welcome to the EDAboard (aka Elektroda) the best site for electronics!
I think you will like it here... 8)
BTW- do you have any more specs for your new version of DSO? I looked at the specs of your previous one and it seemed to be in advanced stage of development both hardware as well as software.
Now if your project could be taken as a basis on which to build more advanced model it would be great because it would give a great boost to the current projects mentioned in this thread that are in more immature stage of develpment. It is of course my private wish only and maybe something that cannot be easily done. :wink:
inside digital oscilloscope
cyr said:
nbn said:
PC-based DSO
Why you use ethernet controller, instead of USB?
triggering dso vhdl
Make_Pic said:
cyr said:
nbn said:
PC-based DSO
Mainly because my laptop has 54Mbps WLAN but no USB2.0 :)
I prefer to plug the scope permanently into my LAN and then have access to it from any computer, and wirelessly. No special device drivers are needed either.
Even so, since I have the ethernet controller on a separate board it wouldn't take all that much work to replace it with some USB2.0 chip if I should change my mind.
cpld dso
to TOTO2001.
I can advice you to look on DASP technology, for this project. Somethere i read that guy cover 1.2GHz bandwith with 80MS/s ADC. Not sure about, but somthere it was.
If u are interested in it i can help a little bit in signal processig field.
Main idea is quite simple, make readings, with frequency smaller than it is needed according to nyquist criteria. But time between readings is randomized.
fpga oscilloscopes
hi folks i also like to make this project with pci bus.so what will be the maximum speed with that?and how can i make the inputs for the probes?
dsoamk3
I think you should have a memory buffer before the pci-bus to maintain constant sample-rate, then the pci-speed doesn't matter much. The probe-inputs is a part of the difficult analog part, take a look at some of the links in this thread...
photomos project
HI,
I have tried for weeks now to access either
**broken link removed** or
and all I get is:
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in C:\Program Files\Apache Group\Apache2\htdocs\phpBB2\db\mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in C:\Program Files\Apache Group\Apache2\htdocs\phpBB2\db\mysql4.php on line 331
phpBB : Critical Error
Could not connect to the database
I have tried with Opera and Mozilla Firefox.
Could somebody help please?
Thank you
Johan Smit
fpga digital storage oscilloscope project
smitjs said:
HI,
h**p://www.soudez.be/Page_Projet2.php or
h**p://164.15.88.56/Page_Projet2.php
and all I get is:
Thank you
Johan Smit
I got the same problem. Can anyone post the schematics here?
