digital multimeter using 8051
kelvinmanoj
Member level 1
chennai
hello friends. i want to design digital multimeter using 8051. pls help me for doing this project, i need a schematic and program. thanks in advance. :)
Standard 8051 dont have ADC, you should use ADC IC with 8051 uC or you can use newer generation of 8051 with builtin ADC.
What you want to measure, you say just multimeter. This can be anything, from amperage, voltage, resistance, power, isolation breakdown, diode, ....
do you want to design like a real multimeter or do you want to use step down transformer to step down voltage to 5V to give it to mcu pin and do you want to use CT (current transformer) for current measuring circuit?
i just want to measure Voltage and Current for both AC and DC... and i need a ADC conversion sample program for this...
Try this code
// Program to interface 3 LDRs with ADC 0808 using three input channels of ADC 0808. The output pins are connected to LCD to show intensity value between (0-255). Controller interrupt is used to generate the clock for driving the ADC 0808.
#include<reg51.h>
sbit ale=P1^0;  //address latch enable
sbit oe=P1^3;  //output enable
sbit sc=P1^1;  //start conversion
sbit eoc=P1^2;  //end of conversion
sbit clk=P1^7;  // clock
sbit ADD_A=P1^4;  //Address pins for selecting input channels.
sbit ADD_B=P1^5;
sbit ADD_C=P1^6;
sfr lcd_data_pin=0xA0;  //Port P2
sbit rs=P3^0;
sbit rw=P3^1;
sbit en=P3^6;
sfr input_port=0x80;  //Port P0
unsigned int key,value,number,ascii1,ascii2,ascii3,flag,temp1,key1/*,data1,data2,data3,data11,data12,data13,data21,data22,data23*/;
void timer0() interrupt 1  // Function to generate clock of frequency 500KHZ using Timer 0 interrupt.
clk=~clk;
void delay(unsigned int count)  // Function to provide time delay in msec.
int i,j;
for(i=0;i<count;i++)
  for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)  //Function to send command to LCD.
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(1);
en=0;
void lcd_data(unsigned char disp)  //Function to send data to LCD.
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(1);
en=0;
lcd_dataa(unsigned char *disp)  //Function to send string data to LCD.
int x;
for(x=0;disp[x]!=0;x++)
  lcd_data(disp[x]);
void lcd_ini()  //Function to inisialize the LCD
lcd_command(0x38);  // for using 8-bit 2 row LCD
delay(5);
lcd_command(0x0F);  // for display on cursor blinking
delay(5);
lcd_command(0x80);
delay(5);  //Force cursor to blink at line 1 positon 0
void BCD()  // Binary to decimal conversion to send the data to LCD
  key1++;
  key=0;
  flag=0;
    number=input_port;
    value=number%10;
number=number/10;
ascii1=value+48;
if(number!=0)
  value=number%10;
  number=number/10;
  ascii2=value+48;
    flag=1;
else
  ascii2=48;
  flag=1;
if(number!=0)
  value=number%10;
    number=number/10;
    ascii3=value+48;
    key=2;
else
  ascii3=48;
  key=2;
if(key1==1)
  lcd_command(0xC0);
if(key1==2)
  lcd_command(0xC5);
if(key1==3)
  lcd_command(0xCA);
if(key==2)
lcd_data(ascii3);
if(flag==1)
lcd_data(ascii2);
lcd_data(ascii1);
if(key1==3)
  key1=0;
  ascii3=0;
  ascii2=0;
  ascii1=0;
  delay(10);
void adc()  //Function to drive ADC
while(1)
   if(temp1==0)
    ADD_C=0;  // Selecting input channel 1 using address lines
    ADD_B=0;
    ADD_A=0;
   if(temp1==1)
    ADD_C=0;  // Selecting input channel 2 using address lines
    ADD_B=0;
    ADD_A=1;
   if(temp1==2)
    ADD_C=0;  // Selecting input channel 3 using address lines
    ADD_B=1;
    ADD_A=0;
   delay(2);
   ale=1;
   delay(2);
   sc=1;
   delay(1);
   ale=0;
   delay(1);
   sc=0;
   while(eoc==1);
   while(eoc==0);
   oe=1;
   BCD();
   delay(2);
   oe=0;
   temp1++;
   if(temp1==3)
   temp1=0;
void main()
  eoc=1;
    ale=0;
   oe=0;
   sc=0;
  TMOD=0x02;  //Timer0 setting for generating clock of 500KHz using interrupt enable mode.
  TH0=0xFD;
  IE=0x82;
  TR0=1;
  temp1=0;
key1=0;
lcd_ini();
lcd_dataa("SN1:");
lcd_dataa(" SN2:");
lcd_dataa(" SN3:");
   adc();
HEY!!! I want to design a Multimeter , using just 2 ports!!! ,
common port is excluded
I want to minimize the error , which causes short circuiting due to low Impedance ,
whenever we transition from voltage mode to current mode
