karbiuch
Junior Member level 1
I have a sensor that has output + -2.5V, max 500k hz. I would like to have a output signal 0-5V. I need to convert differential to singel ended, +-2.5V to 5V.
I tried to use a non-inverting amplifier with a reference voltage - it works. However, when input signal is 0V the output signal is equal to reference voltage 2.5V. I would like to achieve effect when the input is 0V the output is 0V.
Is there a better way of conditioning signal from the differential to single-ended? How to use fully differential amplifier with Vocm?
