nexttym
Member level 1
- Joined
- Jul 16, 2011
- Messages
- 33
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,465
Hi all
I have to measure S parameters for a differential line.But I have a constraint that it is not possible to measure coupling factors,s12(ie b/w adjacent ports) because of the close proximity of ports.Can you suggest a way to calculate the differential S parameters from single ended lines considering the constraint that I can place two probes at the same end..
Thanks in advance
Thanks in advance
