Hi all,
I have a few question about design differential amplifier in Cadence which are:
1. During AC analyze, we will point at one output of the differential amplifier and plot 20dB graph. Does the dB gain indicates 20log (Vout,max - Vout,min) ? Doues Vout,max and Vout,min are in same output point?
2. There are two input port in differential amplifier. Of course, we will give Common mode Voltage at the two input port. What should ac magnitude I should give in these two voltage source for these two input port? 500mV for both inputs or 1V for one input port only? (the purpose to do so is we do not need to recalculate the dB gain based on the gain formula in question 3)
3. Gain = (Vout1-Vout2)/(Vin1-Vin2). What are the Vout1, Vout2, Vin1 and Vin2 refer at the differential amplifier in Cadence?
