difference between volt and power amplifier
electronics_kumar
Advanced Member level 2
Tamilnadu
what is the difference between VOLTAGE AMPLIFIER BJT AND POWER AMPLIFIER BJT.....
HOW /WHEN a transistor becomes power amplifier from voltage amplifier..........
EITHER by means of amount of doping and/or by means of surface area.....
hasitri
Junior Member level 1
voltage amplifiers are linear by nature (class A)
power amplifiers are nonlinear by nature (class b class AB)
they differ not byt their internal things. but ny external connections
V.A resistances are in the order of kΩ n RC connection is preferred
P.A " " Ω n LC in this case
V.A current flowing thru ckt is in mA
P.A " " A
jeffttan
Member level 2
Member level 2
the type of amplifier depends on the configuration of the transistor circuit
