I have a basic question I have been had for a long time.
For designing the inverter, there are two ways to sat the output
to the middle of the supply, assuming Un=2Up.
Re: Difference between the two cases of the designing a inve
For digital design we use the minimum length for both PMOS and NMOS because we wont care about the output resistance of the MOSFET in the saturation region.
Case 1 should be choosen. In digital circuit, the minimum L is choosen, and the channel length modulation can be igonerd, since it just a switching circuit.
* first the "switching" as mentioned in the first post above.
* second: in order to minimize you will chosse the CD (critical dimension = min. allowd length) for all types of digital most. So you choose e.g. l=0.13
The width of nmos will be as fast as you need!
And for pmos the same (in case that you don't need symetry of rise and fall time) or 2-3 times wnmos.
both inverters have the same input caps while the first type has much bigger drivering capability; secondly, not sure your model can support 2*L; thirdly, it's not good for matching; but larger L usually means you have much smaller leakage current, but in these cases, your NMOS gate leakage also increases.
It is not the design task to have the Vth of the inverter in the middle of the supply voltage. The prior task is to guarantee symetric rise and fall times. So the dynamic is of more interst than the static case.
A symetric static (dc) transferfunction differs from symetric rise and fall times since there are different input caps to load for p and n most
