gck
Full Member level 3
rtl schematic and technology schematic
I am using ISE 10.1. I have written following code for dff.
library ieee;
use ieee.std_logic_1164.all;
entity dff is
port (
clk : in std_logic;
rst_a : in std_logic;
din : in std_logic;
qoutb : out std_logic;
qout : out std_logic);
end dff;
architecture dff_arc of dff is
signal qout_s : std_logic;
begin -- dff_arc
dff_p: process (clk, rst_a)
begin -- process dff_p
if rst_a = '1' then -- asynchronous reset (active low)
qout_s <= '0';
elsif clk'event and clk = '1' then -- rising clock edge
qout_s <= din;
end if;
end process dff_p;
qout <= qout_s;
qoutb <= not(qout_s);
end dff_arc;
In RTL view, it showing one dff and qout and qoutb drawn from qout_s with difference of not gate.
In tec view, it is using two dff for two outputs.
library ieee;
entity dff is
port (
clk : in std_logic;
din : in std_logic;
end dff;
begin -- dff_arc
qout_s <= '0';
qout_s <= din;
end if;
end process dff_p;
qout <= qout_s;
end dff_arc;
