dht22 read wrong values
mshh
Full Member level 6
usa
I used this code to read dht22 but it displays wrong value. in simulation, it displays 1.245 % , when i change the humidity it change the tenths numbers and the full scale reading doesn't pass 2%
Chip type               : ATmega8
Program type            : Application
AVR Core Clock frequency: 8,000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 256
#include <mega8.h>
#include <stdint.h>
#include <stdio.h>
#include <delay.h>
#include <stdlib.h>
#define DHT_PORT        PORTD
#define DHT_DDR         DDRD
#define DHT_PIN         PIND
#define DHT11_PIN 1
// Alphanumeric LCD Module functions
#include <alcd.h>
uint8_t c=0,I_RH,D_RH,I_Temp,D_Temp,CheckSum;
 int q;
 	char data[5];
void Request()                /* Microcontroller send start pulse/request */
    DDRD |= (1<<DHT11_PIN);
    PORTD &= ~(1<<DHT11_PIN);    /* set to low pin */
    delay_ms(20);            /* wait for 20ms */
	PORTD |= (1<<DHT11_PIN);	/* set to high pin */
void Response()				/* receive response from DHT11 */
	DDRD &= ~(1<<DHT11_PIN);
	while(PIND & (1<<DHT11_PIN));
	while((PIND & (1<<DHT11_PIN))==0);
uint8_t Receive_data()			/* receive data */
	for (q=0; q<8; q++)
		while((PIND & (1<<DHT11_PIN)) == 0);  /* check received bit 0 or 1 */
		delay_us(30);
		if(PIND & (1<<DHT11_PIN))/* if high pulse is greater than 30ms */
		c = (c<<1)|(0x01);	/* then its logic HIGH */
		else			/* otherwise its logic LOW */
		c = (c<<1);
	return c;
void main(void)
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0xFF;
lcd_init(16);
while (1)
       Request();		/* send start pulse */
		Response();		/* receive response */
		I_RH=Receive_data();	/* store first eight bit in I_RH */
		D_RH=Receive_data();	/* store next eight bit in D_RH */
		I_Temp=Receive_data();	/* store next eight bit in I_Temp */
		D_Temp=Receive_data();	/* store next eight bit in D_Temp */
		CheckSum=Receive_data();/* store next eight bit in CheckSum */
		if ((I_RH + D_RH + I_Temp + D_Temp) != CheckSum)
			lcd_gotoxy(0,1);
			lcd_putsf("Error");
		else
      		lcd_gotoxy(0,0);
	        lcd_putsf("Humidity =");
            lcd_gotoxy(0,10);
			itoa(I_RH,data);
			lcd_puts(data);
			lcd_putsf(".");
			itoa(D_RH,data);
			lcd_puts(data);
			lcd_putsf("%");
            	delay_ms(2000);
I pasted the full code but i don't know where is is the problem, I attached it please modify and post it.
  • code.txt
this code works well for dht11 but for dht22 it shows checksum error in the range from 49-51%
Chip type               : ATmega8
#include <mega8.h>
#include <stdint.h>
#include <stdio.h>
#include <delay.h>
#include <stdlib.h>
#define DHT22       //define DHT22 or DHT11
#define DHT11_PIN 1
#include <alcd.h>
 int q;
     float RH;
   unsigned char data [5];
	for (q=0; q<8; q++)
		delay_us(30);
		c = (c<<1);
	return c;
void main(void)
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0xFF;
lcd_init(16);
while (1)
			lcd_gotoxy(0,1);
			lcd_putsf("Error");
		else
      		lcd_gotoxy(0,0);
            lcd_gotoxy(0,10);
           #ifdef DHT22
            RH= (float) I_RH * 256.0 + D_RH ;
            RH=RH/10.0;
            #else
            RH =  I_RH;
             #endif
             sprintf(data,"%.1f%%  ",RH);
           lcd_puts(data);
            	delay_ms(2000);
