set_dft_drc_configuration -internal_pins enable
set_dft_signal -view existing_dft -type ScanClock -hookup_pin PAD_Clock/C -timing {5 15}
set_dft_signal -view existing_dft -type Reset -hookup_pin SYNC_DFC1_2/Q -active_state 0
set_dft_signal -view spec -type ScanEnable -hookup_pin PAD_Test/C -port Test -active_state 1
set_dft_signal -view existing_dft -type TestMode -hookup_pin PAD_Test/C -port Test -active_state 1
set_dft_signal -view spec -type ScanDataIn -hookup_pin PAD_SDI/C -port SDI
set_dft_signal -view spec -type ScanDataOut -hookup_pin PAD_SDO/I -port SDO
create_test_protocol
dft_drc
set_scan_configuration -chain_count 1
preview_dft
insert_dft
dft_drc
