Devices connected to different phase of 400V
Zedman
Full Member level 6
Hungary
Dear all,
could it cause any kind of damage if a device (ex. a TV set) connected to Phase 1 of a 400V outlet getting connected to another (SetTopBox) which is on the Phase 2 of the same outlet?
Could the 120 degree phase shift cause any problem?
thanks,
Zedman
I hope that you mean that you are connecting the devices between a Phase and Neutral.
As long as both Phases share the same neutral, then it does not matter.
Reactions: Zedman
    Zedman
I have three phase at home, and various power points and lights are powered between the different phases and neutral.
That is how the system is works.
Reactions: Zedman
    Zedman
Yes of course they use the same neutral. I was just worried about the phase difference.
thanks,
Zedman
