Detracting factor applied for the common clock path
aditya1579
Member level 2
Member level 2
All,
What derating factor do we apply for the common clock path between launch and capture clocks, when calculating CPPR or common path pessimism removal ?
And what is the reason ?
Aditya
I usually used 5% derating on data and clock, during PnR and STA. that gives more margin.
It s good to enable by default the CPPR, to removed the derating impact for the common part of the launch and capture paths.
Because for the common path, it could not be worst for the launch and debate for the capture path for the same analys.
