Hi Folks
I am wondering if someone could help me with a circuit design that given a voltage (~0-10V range) and a threshold value (say 7V) would change output if the voltage rose above the threshold voltage.
The threshold however, is not set. Its controlled by a processor output pin(s).
Little bit inexperienced as to what is commercially available (what I should be searching for) and what I may need to design myself. If the threshold was set instead of variable, I wouldn't have too much difficulty, but this has confused me a bit.
Thanks
