You can also sense the voltage drop across the LED. If the LED has failed open, the voltage will go to the power supply voltage. If the LED failed short, the voltage will go to zero.Taner said:you can use a current sense of the LED display, with current sensor
You did not say that in the first post.khongai said:but LED display very far from me ( about 1km)
Would an LED display have a single currelt-limiting resistor? I doubt it.mondunno said:scan leds one by one. just check the drop across the "current limit resistance"(the one in series, with all leds) which ever led shows VCC as drop, its disconnected
