Details of 3-bit flash ADC (CMOS technology)
sivamit
Full Member level 4
can anyone please give me the details of any 3 bit flash ADC(CMOS technology) ?
itz very urgent...
Thank you...
Re: 3 bit flash CMOS ADC
wot exactly u want ??
wat do u want to know abt it?
A flash converter is just comparators for each discrete level (for your 3-bit that would mean 7 comparators), and usually a resistor string divider to provide the reference levels for comparison.
The output of the 7 comparators then goes through "thermometer-to-binary" conversion logic to go from the 7 levels to the 3 binary outputs.
If you think a bit about the nature of the output of the comparators as the input analog level varies, you will see why the name of "thermometer."
hope this can help
the paper is very good when i read
some paper in ISSCC is OK
see the book "system design" by wolf. it iwll help u.
Can you tell me the full name of the book?
refer data conversion system design by razavi
it is vlsi system design by wolf
what is the "thermometer-to-binary conversion logic" ??
should i use a xor gate?
---------- Post added at 05:21 ---------- Previous post was at 05:16 ----------
hope this can help
in this .doc file
what kind of encoder is being used??
generally a 8 to 3 bit encoder means
00000100 == 101
but the encoder in this doc shows different results
for a 3 bit flash adc use 8 resistors(the 1st and the last resistors should be half of the resistance of the rest resistors)
then connect 7 comparators with the reference input through the resistors
the 7comparators outputs should then be feed to thermometer output(xor gates)
the xor outputs should then be feed to encoder inputs
the encoder outputs are the ultimate result for the 3bit flash adc
