You could download the HFSS_10 tutorial guide by using some P2P tools such as eMule. There is a detailed example of creating and simulating rectangular patch antenna in this guide.menz said:[/b]plz help me out how to design a microstrip rectangular patch antenna in HFSS 10...
i dont know wat is the mesh operation??can anyboddy give me da link about tutorial..
im too much worried plzzz help me out..
You should check the procedure of your design. Maybe, something wrong?!?!menz said:i have designed a patch antenna at 10 ghz but result is coming on 14 ghz.i dont know what is the prob..
Added after 3 minutes:
how can i verify that dominont mode exist at resonnnat freq?/
Did you try the link provided by rautio's post? I believe this uses closed-form equations to come up with patch antenna dimensions. It then generates sonnet files that you can use or ignore, your choice. But you should be able to find the equations you need from the .m files (maybe the file called "FindDims.m"?). I haven't look inside these files, so if they aren't what you need, then post again.srikanth805 said:can any one help me in finding equations on microstrip patch designing..so that i can write MATLAB programs on them
