irfan ahmad
Full Member level 3
- Joined
- Feb 17, 2012
- Messages
- 181
- Helped
- 54
- Reputation
- 108
- Reaction score
- 54
- Trophy points
- 1,318
- Location
- LAHORE PAKISTAN
- Activity points
- 2,211
How can I change the delay 5Min and 3Sec. Thanks Alotzzzz,
How can I change timmer to 5Min and 3Sec; Thankzzzzz
----v----
+B < 1 | | 14 > -B
A5 < 2 | | 13 > A0 > AN0 adc input
A4 < 3 | | 12 > A1 > AN1 relay1
A3 < 4 | | 11 > A2 > AN2 relay2
C5 < 5 | | 10 > C0 > AN4 relay3
C4 < 6 | | 9 > C1 > AN5 relay4
AN7 < C3 < 7 | | 8 > C2 > AN6 led
/////////////////initialization/////////////////////
#include <16f676.h>
#device adc=10
#use delay(clock=4000000)
#fuses intrc_io
#fuses NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
/////////////////////pins lables///////////////////
#define relay1 pin_a1 //main change
#define relay2 pin_a2 //main change
#define relay3 pin_c0 //outputchange
#define relay4 pin_c1 //output on off
#define led pin_c4 //
#define sw pin_a3 //active low
#define low_limit 1550 // limit for low voltage
#define high_limit 2450 // limit for high voltage
#define low_ok 2100 // value for main low function compleate
#define high_ok 2440 // value for main high function compleate
///////////////////labling of syntex////////////////
#define on output_high
#define off output_low
unsigned int32 main_v=1000,count;
unsigned int8 step=1,time=0,x;
int1 fault=0;
unsigned int8 delay=30;
void adc_read (void);
void relay_Set (void);
void main_high (void);
void main_low (void);
void initialize(void);
void start_up (void);
/////////////////////timer1 isr//////////////////////
#int_timer1
void timer1_subrutine(void)
set_timer1(65536-62500); // after 0.5S interrupt will rise
time++;
output_toggle(led);
if (((time>delay)||(input(sw)==0)) && (fault==0))
time=0; // for next round
on(led);
on(relay4);
disable_interrupts(int_timer1);
disable_interrupts(global);}
void main()
initialize();
WHILE(1)
start_up();
////////////////////normal loop///////////////////////////////
do
for(x=0; x<20; x++) //loop to perform voltage stabalization function
// if gap is larg then only one step can not stabal voltage
adc_read();
if(main_v>2410)
{step--; if(step<1)step=1; relay_set();} //239V
else if(main_v<1630) //200V
{step++; if(step>6)step=6;relay_set();}
else;
while((main_v<high_limit)&&(main_v>low_limit)); // check the limits
/////////////////////under over section///////////////////////
fault=1;
time=0; // reset timer if it was running
if(main_v>=high_limit) main_high(); // call relevent function
else if(main_v<=low_limit) main_low(); // call relevent function
disable_interrupts(int_timer1); // reset timer and interrupt
fault=0;
enable_interrupts(int_timer1);
enable_interrupts(global);
off(relay4);
off(relay3);
off(relay2);
off(relay1);
delay_ms(500);
while(main_v<low_ok)
time=0;
adc_read();
off(relay4);
on(relay1);
on(relay2);
on(relay3);
delay_ms(500);
while(main_v>= high_ok)
time=0;
adc_read();
delay_ms(20);
main_v =read_adc();
main_v=main_v*5000/1023;
void initialize (void)
off(relay4);
on(relay1);
on(relay2);
on(relay3);
/////////////input output setting////////////////////
set_tris_a(0b11110001);
set_tris_c(0b11111000);
output_float(pin_a0);
setup_adc(adc_clock_div_64);
SETUP_ADC_PORTS(sAN0 ) ;
delay_ms(100);
adc_read();
setup_timer_1(t1_internal | t1_div_by_8);
set_timer1(65536-62500); //initialize for correct time
enable_interrupts(global); //unmasked interrupts enable
void relay_set (void)
if(step==1)
{ on(relay1);
on(relay2);
on(relay3);}
else if(step==2)
{on(relay1);
on(relay2);
off(relay3);}
else if (step==3)
{on(relay1);
off(relay2);
on(relay3);}
else if (step==4)
{on(relay1);
off(relay2);
off(relay3);}
else if (step==5)
{off(relay1);
off(relay2);
on(relay3);}
else if (step==6)
{off(relay1);
off(relay2);
off(relay3);}
else;
This is source code.
compiler is ccs pic c . THIS COMPANY https://www.ccsinfo.com/content.php?page=compilers
Code:////////////////////////////////////////////////// /* ----v---- +B < 1 | | 14 > -B A5 < 2 | | 13 > A0 > AN0 adc input A4 < 3 | | 12 > A1 > AN1 relay1 A3 < 4 | | 11 > A2 > AN2 relay2 C5 < 5 | | 10 > C0 > AN4 relay3 C4 < 6 | | 9 > C1 > AN5 relay4 AN7 < C3 < 7 | | 8 > C2 > AN6 led --------- */ /////////////////initialization///////////////////// #include <16f676.h> #device adc=10 #use delay(clock=4000000) #fuses intrc_io #fuses NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR /////////////////////pins lables/////////////////// #define relay1 pin_a1 //main change #define relay2 pin_a2 //main change #define relay3 pin_c0 //outputchange #define relay4 pin_c1 //output on off #define led pin_c4 // #define sw pin_a3 //active low #define low_limit 1550 // limit for low voltage #define high_limit 2450 // limit for high voltage #define low_ok 2100 // value for main low function compleate #define high_ok 2440 // value for main high function compleate ///////////////////labling of syntex//////////////// #define on output_high #define off output_low //////////////////////////////////////////////////// unsigned int32 main_v=1000,count; unsigned int8 step=1,time=0,x; int1 fault=0; unsigned int8 delay=30; //////////////////////////////////////////////////// void adc_read (void); void relay_Set (void); void main_high (void); void main_low (void); void initialize(void); void start_up (void); /////////////////////timer1 isr////////////////////// #int_timer1 void timer1_subrutine(void) { set_timer1(65536-62500); // after 0.5S interrupt will rise time++; output_toggle(led); if (((time>delay)||(input(sw)==0)) && (fault==0)) { time=0; // for next round on(led); on(relay4); disable_interrupts(int_timer1); disable_interrupts(global);} } //////////////////////////////////////////////////////// void main() { initialize(); WHILE(1) { start_up(); ////////////////////normal loop/////////////////////////////// do { for(x=0; x<20; x++) //loop to perform voltage stabalization function // if gap is larg then only one step can not stabal voltage { adc_read(); if(main_v>2410) {step--; if(step<1)step=1; relay_set();} //239V else if(main_v<1630) //200V {step++; if(step>6)step=6;relay_set();} else; } } while((main_v<high_limit)&&(main_v>low_limit)); // check the limits /////////////////////under over section/////////////////////// fault=1; time=0; // reset timer if it was running if(main_v>=high_limit) main_high(); // call relevent function else if(main_v<=low_limit) main_low(); // call relevent function disable_interrupts(int_timer1); // reset timer and interrupt disable_interrupts(global); fault=0; } } /////////////////////////////////////////////////////////////// void main_low (void) { enable_interrupts(int_timer1); enable_interrupts(global); off(relay4); off(relay3); off(relay2); off(relay1); delay_ms(500); while(main_v<low_ok) { time=0; adc_read(); } } /////////////////////////////////////////////////////////////// void main_high (void) { enable_interrupts(int_timer1); enable_interrupts(global); off(relay4); on(relay1); on(relay2); on(relay3); delay_ms(500); while(main_v>= high_ok) { time=0; adc_read(); } } /////////////////////////////////////////////////////////// void adc_read (void) { delay_ms(20); main_v =read_adc(); main_v=main_v*5000/1023; } //////////////////////////////////////////////////////////////////////////////// void initialize (void) { off(relay4); on(relay1); on(relay2); on(relay3); /////////////input output setting//////////////////// set_tris_a(0b11110001); set_tris_c(0b11111000); output_float(pin_a0); setup_adc(adc_clock_div_64); SETUP_ADC_PORTS(sAN0 ) ; } /////////////////////////////////////////////////////////////////////////////////// void start_up (void) { delay_ms(100); adc_read(); setup_timer_1(t1_internal | t1_div_by_8); enable_interrupts(int_timer1); set_timer1(65536-62500); //initialize for correct time enable_interrupts(global); //unmasked interrupts enable } /////////////////////////////////////////////////////////// void relay_set (void) { if(step==1) { on(relay1); on(relay2); on(relay3);} else if(step==2) {on(relay1); on(relay2); off(relay3);} else if (step==3) {on(relay1); off(relay2); on(relay3);} else if (step==4) {on(relay1); off(relay2); off(relay3);} else if (step==5) {off(relay1); off(relay2); on(relay3);} else if (step==6) {off(relay1); off(relay2); off(relay3);} else; } //\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\
O = Output, I = Input
_________
Vdd | 1 14 | Vss
(I) SW1 --> RA5 | 2 13 | AN0 <-- ADC_Value (I) For O\P feed bauck
(I) SW2 --> RA4 | 3 12 | RA2 --> RL1 (O)
MCLR | 4 11 | N\C
(O) L1 <-- RC5 | 5 10 | RC0 --> RL2 (O)
(O) L1 <-- RC4 | 6 9 | RC1 --> RL3 (O)
(O) BZR <-- RC3 | 7 8 | RC2 --> RL4 (O)
Dont tease us Ms Sahu
There is only 4 relays. Other is LED (rc4) and it starts blinking when out of range. If you connect a relay to this pin, it will start to do "tic tic".only 1 step work fine
step 6 & when i increas i\p volt . mcu sence step 5.
then relay doing tik tak tik tak sound .
