rahdirs
Advanced Member level 1
- Joined
- May 22, 2013
- Messages
- 424
- Helped
- 93
- Reputation
- 192
- Reaction score
- 91
- Trophy points
- 1,308
- Location
- Mordor
- Activity points
- 4,492
Voltage Controlled switch
Hi all,
I need to design a circuit that operates in different paths at different voltages.
I have a voltage source whose voltage varies slowly(4 V - 18 V),but it gives out high currents.
I mean i need a kind of voltage dependent switch that does not hinder flow of current.
Eg:If Voltage is at 6 V,the switching circuitry switches to close path 1 & current only flows in path 1
If Voltage is at 9 V,the switching circuit switches on to close path 2,open path 1 & current flows in path 2
.............. for other voltage levels
I tried using window comparator with op-amp but op-amps & high currents!!!!!!
Hi all,
