Design of MPPT for Solar panel
hynix
Member level 5
Member level 5
Inda
timnolan + homepower
Hi Those who are interested for the same can look at the link below
free HOME-POWER Journal for free
Also I am interested to have compleat design of MPPT(Maximum Power Point Tracker) for Solar pannel any one out there intereste to share more info about that.
thanks :p
solvarg
Full Member level 2
Full Member level 2
Sweden
timnolan mppt
thanks :p
This looks really interesting! I´am on!
Mr.Cool
Advanced Member level 2
tim nolan mppt
hi there;
i know a lot about MPPT and designing a line synchronized inverter (find a post with subject "Photovoltaic" i discuss a problem i am having). i would be happy to discuss and/or share information on this subject.
you can post here, or private message me.
Mr.Cool
solvarg
Full Member level 2
Full Member level 2
Sweden
Re: Home Made Power
thanks :p
hynix, I guess you have electrical solar panels in mind? My need is an MPPT device for an "water" solar panel. As I see it, it should do the same job. I have pictured the device as a time and date controlled positioning system. Let the calendar control elevation and rotation of the panel.
I appreciate your company MrCool.
What are your thug’s guys?
Mr.Cool
personally i am using the "incremental conductance" method to find the maximum power from a solar panel.
but i can't start on the software cause i can't get my programmer to communicate with my software :(
i've spent many many hours fiddling with it... grrr....
Mr.Cool
pico
Full Member level 6
Full Member level 6
humanbynature
Newbie level 1
Newbie level 1
Re: Home Made Power
I've found a relatively cheap way to create my own power. Just buy a Marine windmill for around $900-1200, and attach it to an synchronized inverter. For less then around $2000 you could be producing around 400watts. Enough to power most of the lights in most homes.
These windmills are unobtrusive, easy to install and quiet.
This is just me, thinking outside of the box.
froggy
Member level 5
Member level 5
Re: Home Made Power
Have you seen the Tim Nolan MPPT:
Its a very interesting design based on sw runing on a pic. The software also regulary turn the MPPT on and off to measure the improved effiency for debug purpose.
/Froggy
