Zangetsu57
Member level 4
Hello everyone,
I need to design and fabricate a simple coupled-line microstrip balun, but don't know where to start. The best reference I've found is here: **broken link removed** Are there good references for how to do this? I have HFSS but not ADS, but I think HFSS will work for this job.
One other thing: If I can design the balun to operate at a few hundred watts, that is a huge plus.
A bit of background: What I'm trying to do is characterize an antenna array that has a single balanced input. It should have an impedance of 200 ohms; I need to verify this. The idea is to design, fabricate, and measure the balun, then the antenna with the balun, and remove the effects of the balun in software afterwards to get the response of the antenna.
The balun input and output will be coax so I can test the balun with a VNA. The center conductors of the coax at the balanced end will connect to an antenna via a short piece of metal wire.
Any advice is greatly appreciated!
