pratyush23
Newbie level 3
I wish to design a digital carrier generator, the diagram of which i am attaching herein..for the same i have used the following building blocks:
1> 2:1 Mux(multibit)
2> Digital Integrator (multibit)
3> A Delta function block (unit impulse function)
4> A Clock
5> A 4x4 bit multiplier, wherein only the first 4 bits of the product have been considered.
I ran the code and it synthesized perfectly well..but on generation of test bench waveform, the output ports were undefined..
i m unable to figure out as to how to supply the values to the building blocks through the signals...
Please suggest the required changes/errors..
The codes for each building block has been attached below.
Thanks.
CODES:
1> CARRIER GENERATOR
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY carrier_gen IS
GENERIC (
WIDTH : INTEGER := 4
PORT (
y : OUT STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
x : IN STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0)
END carrier_gen;
ARCHITECTURE trans OF carrier_gen IS
SIGNAL a : STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
SIGNAL b : STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
SIGNAL c : STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
SIGNAL del : STD_LOGIC;
SIGNAL clock : STD_LOGIC;
-- Declare intermediate signals for referenced outputs
SIGNAL y_xhdl0 : STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
Component mux_2to1 IS
GENERIC (
PORT (
c : OUT STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
a : IN STD_LOGIC;
sel : IN STD_LOGIC;
b : IN STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0)
END component;
component dig_int IS
GENERIC (
PORT (
x : IN STD_LOGIC_VECTOR(WIDTH - 1 DOWNTO 0);
clock : IN STD_LOGIC
END component;
component multiply is
PORT (
prod : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
a : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(3 DOWNTO 0)
end component;
component delta IS
PORT (
del : OUT STD_LOGIC
END component;
component clk_gen is
port(clock ut std_logic);
end component;
BEGIN
-- Drive referenced outputs
y <= y_xhdl0;
m1 : mux_2to1 PORT MAP (c,del,del,b);
d1 : dig_int PORT MAP (a,c,clock);
d2 : dig_int PORT MAP (y_xhdl0,a,clock);
m2 : multiply PORT MAP (b,y_xhdl0,x);
d3 : delta PORT MAP (del);
c2 : clk_gen PORT MAP (clock);
END trans;
2>CLOCK
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity clk_gen is
end clk_gen;
architecture Behavioral of clk_gen is
SIGNAL clock_xhdl0 : STD_LOGIC;
BEGIN
clock <= clock_xhdl0;
PROCESS
BEGIN
for i in 1 to 10 loop
clock_xhdl0 <= '1';
wait for 100 ns;
clock_xhdl0 <= NOT(clock_xhdl0);
wait for 100 ns;
end loop;
END PROCESS;
end Behavioral;
3>Delta
LIBRARY ieee;
ENTITY delta IS
PORT (
del : OUT STD_LOGIC
END delta;
ARCHITECTURE trans OF delta IS
BEGIN
PROCESS
BEGIN
WAIT FOR 0 ns;
del <= '1';
WAIT FOR 100 ns;
del <= '0';
WAIT;
END PROCESS;
END trans;
4>Integrator
LIBRARY ieee;
ENTITY dig_int IS
GENERIC (
PORT (
END dig_int;
ARCHITECTURE trans OF dig_int IS
SIGNAL z : STD_LOGIC_vector(WIDTH - 1 downto 0):="0000";
BEGIN
y <= y_xhdl0;
PROCESS (x, z)
BEGIN
y_xhdl0 <= x + z;
END PROCESS;
PROCESS (clock)
BEGIN
IF (clock'EVENT AND clock = '1') THEN
z <= y_xhdl0;
END IF;
END PROCESS;
END trans;
5>Multiplier
library IEEE;
--library UNISIM;
entity multiply is
PORT (
end multiply;
architecture Behavioral of multiply is
constant n:integer :=4;
subtype plary is std_logic_vector(n-1 downto 0);
type pary is array(0 to n) of plary;
signal pp,pc,ps ary;
begin
pgen:for j in 0 to n-1 generate
pgen1:for k in 0 to n-1 generate
pp(j)(k)<=a(k) and b(j);
end generate;
pc(0)(j)<='0';
end generate;
ps(0)<=pp(0);
prod(0)<=pp(0)(0);
addr:for j in 1 to n-1 generate
addc:for k in 0 to n-2 generate
ps(j)(k)<=pp(j)(k) xor pc(j-1)(k) xor ps(j-1)(k+1);
pc(j)(k)<=(pp(j)(k) and pc(j-1)(k)) or
(pp(j)(k) and ps(j-1)(k+1)) or
(pc(j-1)(k)and ps(j-1)(k+1));
end generate;
prod(j)<=ps(j)(0);
ps(j)(n-1)<=pp(j)(n-1);
end generate;
end Behavioral;
6> 2:1 MUX
LIBRARY ieee;
ENTITY mux_2to1 IS
GENERIC (
PORT (
a : IN STD_LOGIC;
sel : IN STD_LOGIC;
END mux_2to1;
ARCHITECTURE trans OF mux_2to1 IS
BEGIN
c <= ("000" & a) WHEN (sel = '1') ELSE
b;
END trans;
4> A Clock
Thanks.
CODES:
LIBRARY ieee;
GENERIC (
PORT (
END carrier_gen;
GENERIC (
PORT (
a : IN STD_LOGIC;
sel : IN STD_LOGIC;
END component;
GENERIC (
PORT (
END component;
PORT (
end component;
component delta IS
PORT (
del : OUT STD_LOGIC
END component;
port(clock
end component;
BEGIN
y <= y_xhdl0;
END trans;
2>CLOCK
library IEEE;
--library UNISIM;
entity clk_gen is
port(clock
end clk_gen;
BEGIN
PROCESS
BEGIN
clock_xhdl0 <= '1';
wait for 100 ns;
wait for 100 ns;
end loop;
END PROCESS;
end Behavioral;
3>Delta
LIBRARY ieee;
ENTITY delta IS
PORT (
del : OUT STD_LOGIC
END delta;
BEGIN
PROCESS
BEGIN
WAIT FOR 0 ns;
del <= '1';
WAIT FOR 100 ns;
del <= '0';
WAIT;
END PROCESS;
END trans;
4>Integrator
LIBRARY ieee;
ENTITY dig_int IS
GENERIC (
PORT (
END dig_int;
BEGIN
y <= y_xhdl0;
PROCESS (x, z)
BEGIN
y_xhdl0 <= x + z;
END PROCESS;
PROCESS (clock)
BEGIN
z <= y_xhdl0;
END IF;
END PROCESS;
END trans;
5>Multiplier
library IEEE;
--library UNISIM;
entity multiply is
PORT (
end multiply;
signal pp,pc,ps
begin
end generate;
pc(0)(j)<='0';
end generate;
ps(0)<=pp(0);
prod(0)<=pp(0)(0);
end generate;
prod(j)<=ps(j)(0);
end generate;
end Behavioral;
6> 2:1 MUX
LIBRARY ieee;
ENTITY mux_2to1 IS
GENERIC (
PORT (
a : IN STD_LOGIC;
sel : IN STD_LOGIC;
END mux_2to1;
BEGIN
b;
END trans;
