design for a Power Supply (Vin 60-70V, Voutput adj, 120ma
freetools
Newbie level 6
Newbie level 6
Hi
I need to design some power supply with this characteristics:
Vin: 60-70V
Vout: Adj (3.3v..5v..10v)
Iout: 100..150 ma
Ignd: really low (as low as posible).
I have only 100 mW for all the circuit, and I need a power suppy with very very low Ignd (very power loss)
tia!
regards
Hi
Firt i think that you will need an isolated dc-dc power supply for that high voltage.(it posible that you need a second dc-dc regulator too,after you have a first low voltage from the high votage in).
you have some comp that make dc-dc converters
first option look on linear:
https://www.linear.com/prod/pft.html?product_family=power
chose switch-regulators/step-down/high-voltage-input(vin>=36)
and you get some regulators
some example :
https://www.linear.com/pdf/1725f.pdf
second option maxim
Best regards.
Vishay-Siliconix is a good alternative for high input voltages (so-called Telecom voltages)
See for example Si9117, and several other possibilities - depending on features needed:
Good luck,
Ted
