[SOLVED] design compiler timing report
mehran1367
Member level 3
Member level 3
hi,
how can I create a timing report from all the paths between several inputs and one specific output?
I wan to have the delay of all fan-in in a text file.
plz help
i used
get_timing_paths -to U602/Y > report.txt
the content of the report.txt is
{path0}
I think the command must have other switches?
help
well,
i found that.
set mylist [all_inputs]
foreach_in_collection iter $mylist {
report_timing -from $iter -to U602/Y
} > t1.txt
It will give only one path. So use -nworst <> -max_paths <> switches to get the all other paths.
