Design and Construction of Microcontroller Training Board
kohtwe
Junior Member level 2
microcontroller training board
Hello!
Would you mind you will help.
I need design and construction of Microcontroller Training Board.
I known applification of Microcontroller.
I think, you may help.
8051 trainer board
What type of controller chip you want to use?? PIC, AVR...
Also, try searching the web, you have so many examples.
Bye.
80c51 trainer board
Hay Guy,
I think you are developing Microcontroller (PIC) for your ME Thesis. I can build a training board what you need. If your final defence is very near, contact me by mail.
I think I am from the same country with you.
test board construction
check www.circuitcellar.com/contests click the AVR2004 Contest and you will find in the distinctive excellence section a project for a tranning board for atmega128 with schimatics and source code
contruction of microcontroller training board
Hi!
I want to use with 8051 Microcontroller.
All Thank
8051 microcontroller trainer board with 4 adc
You can have a look at the MCB900 board from Keil posted with schematics on the Keil website:
www.keil.com/mcb900
Well the LPC900 is a 2-clock 8051.
If it is for the original 8051, the link to Rigel might be helpful:
https://www.rigelcorp.com/__doc/8051/R31JPaV2.pdf
It is based on their board and there are no schematics for the board but there is a partlist, which can also be helpful.
Bob
construction of imcrocontroller
hi
i think any training board should contains many things that don't depend on the processor type, like:
1.Keybad matrix
2.LCD
3. 7 seg
4. some leds
5. serial interface
6.some switches
7.ADC and /or DAC
and so on
hope that help u
Slam
Ahmed
www.i-g.org
training board 8051
batronix.com has test board
Thesis
can anyone help me in the thesis of the board?
I dont know how to start cuz i cant find any thesis one microcontroller board design and construction to look for some guidance.
Im really worried cuz i have to submitt it in 7 days.:S
im using atmel 89s53.
modules are
Keyboard
lcd graphics
lcd text
7 seg
led panel
relay panel
dc motor
stepper motor
dac
adc
eeprom with Real Time Clock
interfacing with 8255
burner for the controller
I'd really appreciate your help.
Rist you need a programmer, I sugest You to bye one. Not to make ... for proto board you can get one of these bread boards. these boards with lcd, memory, keyboard ... are very expensive for hobby use. Start one by one. First some small led programs... to understand the conception and after that you will need these "pro" boards :)
before 2 Year i work with 8051 , now I use AVR and think is better. If can help You welcome
regards from Bulgaria
