Depending on CRC polynomial....How are new values calculated
Guru59
Full Member level 4
Full Member level 4
How the New CRC values are calculated.....in the below example
// File: CRC32_D32.v
// Copyright (C) 1999-2003 Easics NV.
// This source file may be used and distributed without restriction
// provided that this copyright statement is not removed from the file
// and that any derivative work contains the original copyright notice
// and the associated disclaimer.
// THIS SOURCE FILE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS
// OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
// WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// Purpose: Verilog module containing a synthesizable CRC function
// * polynomial: (0 1 2 4 5 7 8 10 11 12 16 22 23 26 32)
// * data width: 32
// Info: tools(at)easics.be
// https://www.easics.com
module crc32_D32(DATA_IN, CLK, RESET, START, init, CRC_OUT,neg_crc,crc);
input [31:0] DATA_IN;
input CLK;
input RESET;
input START;
input init;
output [31:0] CRC_OUT;
output [31:0]neg_crc;
output [31:0]crc;
reg [31:0] CRC_OUT;
reg [31:0]neg_crc;
reg [31:0]crc;
always @(posedge CLK)
begin
if (!RESET) begin
// CRC_OUT = 32'h00;
CRC_OUT = 32'hffffffff;
end
else if (init) begin
end
else if (START) begin
CRC_OUT = nextCRC32_D32(DATA_IN, CRC_OUT);
neg_crc = ~ (CRC_OUT);
crc = {neg_crc[0],neg_crc[1],neg_crc[2],neg_crc[3],neg_crc[4],neg_crc[5],neg_crc[6],neg_crc[7],neg_crc[8],neg_crc[9],neg_crc[10],
neg_crc[11],neg_crc[12],neg_crc[13],neg_crc[14],neg_crc[15],neg_crc[16],neg_crc[17],neg_crc[18],neg_crc[19],neg_crc[20],
neg_crc[21],neg_crc[22],neg_crc[23],neg_crc[24],neg_crc[25],neg_crc[26],neg_crc[27],neg_crc[28],neg_crc[29],neg_crc[30],
neg_crc[31]};
end
end
// polynomial: (0 1 2 4 5 7 8 10 11 12 16 22 23 26 32)
// data width: 32
// convention: the first serial data bit is D[31]
function [31:0] nextCRC32_D32;
input [31:0] Data;
input [31:0] CRC;
reg [31:0] D;
reg [31:0] C;
reg [31:0] NewCRC;
begin
D = Data;
C = CRC;
NewCRC[0] = D[31] ^ D[30] ^ D[29] ^ D[28] ^ D[26] ^ D[25] ^ D[24] ^
D[16] ^ D[12] ^ D[10] ^ D[9] ^ D[6] ^ D[0] ^ C[0] ^
C[6] ^ C[9] ^ C[10] ^ C[12] ^ C[16] ^ C[24] ^ C[25] ^
C[26] ^ C[28] ^ C[29] ^ C[30] ^ C[31];
NewCRC[1] = D[28] ^ D[27] ^ D[24] ^ D[17] ^ D[16] ^ D[13] ^ D[12] ^
D[11] ^ D[9] ^ D[7] ^ D[6] ^ D[1] ^ D[0] ^ C[0] ^ C[1] ^
C[6] ^ C[7] ^ C[9] ^ C[11] ^ C[12] ^ C[13] ^ C[16] ^
C[17] ^ C[24] ^ C[27] ^ C[28];
NewCRC[2] = D[31] ^ D[30] ^ D[26] ^ D[24] ^ D[18] ^ D[17] ^ D[16] ^
D[14] ^ D[13] ^ D[9] ^ D[8] ^ D[7] ^ D[6] ^ D[2] ^
D[1] ^ D[0] ^ C[0] ^ C[1] ^ C[2] ^ C[6] ^ C[7] ^ C[8] ^
C[9] ^ C[13] ^ C[14] ^ C[16] ^ C[17] ^ C[18] ^ C[24] ^
C[26] ^ C[30] ^ C[31];
NewCRC[3] = D[31] ^ D[27] ^ D[25] ^ D[19] ^ D[18] ^ D[17] ^ D[15] ^
D[14] ^ D[10] ^ D[9] ^ D[8] ^ D[7] ^ D[3] ^ D[2] ^
D[1] ^ C[1] ^ C[2] ^ C[3] ^ C[7] ^ C[8] ^ C[9] ^ C[10] ^
C[14] ^ C[15] ^ C[17] ^ C[18] ^ C[19] ^ C[25] ^ C[27] ^
C[31];
NewCRC[4] = D[31] ^ D[30] ^ D[29] ^ D[25] ^ D[24] ^ D[20] ^ D[19] ^
D[18] ^ D[15] ^ D[12] ^ D[11] ^ D[8] ^ D[6] ^ D[4] ^
D[3] ^ D[2] ^ D[0] ^ C[0] ^ C[2] ^ C[3] ^ C[4] ^ C[6] ^
C[8] ^ C[11] ^ C[12] ^ C[15] ^ C[18] ^ C[19] ^ C[20] ^
C[24] ^ C[25] ^ C[29] ^ C[30] ^ C[31];
NewCRC[5] = D[29] ^ D[28] ^ D[24] ^ D[21] ^ D[20] ^ D[19] ^ D[13] ^
D[10] ^ D[7] ^ D[6] ^ D[5] ^ D[4] ^ D[3] ^ D[1] ^ D[0] ^
C[0] ^ C[1] ^ C[3] ^ C[4] ^ C[5] ^ C[6] ^ C[7] ^ C[10] ^
C[13] ^ C[19] ^ C[20] ^ C[21] ^ C[24] ^ C[28] ^ C[29];
NewCRC[6] = D[30] ^ D[29] ^ D[25] ^ D[22] ^ D[21] ^ D[20] ^ D[14] ^
D[11] ^ D[8] ^ D[7] ^ D[6] ^ D[5] ^ D[4] ^ D[2] ^ D[1] ^
C[1] ^ C[2] ^ C[4] ^ C[5] ^ C[6] ^ C[7] ^ C[8] ^ C[11] ^
C[14] ^ C[20] ^ C[21] ^ C[22] ^ C[25] ^ C[29] ^ C[30];
NewCRC[7] = D[29] ^ D[28] ^ D[25] ^ D[24] ^ D[23] ^ D[22] ^ D[21] ^
D[16] ^ D[15] ^ D[10] ^ D[8] ^ D[7] ^ D[5] ^ D[3] ^
D[2] ^ D[0] ^ C[0] ^ C[2] ^ C[3] ^ C[5] ^ C[7] ^ C[8] ^
C[10] ^ C[15] ^ C[16] ^ C[21] ^ C[22] ^ C[23] ^ C[24] ^
C[25] ^ C[28] ^ C[29];
NewCRC[8] = D[31] ^ D[28] ^ D[23] ^ D[22] ^ D[17] ^ D[12] ^ D[11] ^
D[10] ^ D[8] ^ D[4] ^ D[3] ^ D[1] ^ D[0] ^ C[0] ^ C[1] ^
C[3] ^ C[4] ^ C[8] ^ C[10] ^ C[11] ^ C[12] ^ C[17] ^
C[22] ^ C[23] ^ C[28] ^ C[31];
NewCRC[9] = D[29] ^ D[24] ^ D[23] ^ D[18] ^ D[13] ^ D[12] ^ D[11] ^
D[9] ^ D[5] ^ D[4] ^ D[2] ^ D[1] ^ C[1] ^ C[2] ^ C[4] ^
C[5] ^ C[9] ^ C[11] ^ C[12] ^ C[13] ^ C[18] ^ C[23] ^
C[24] ^ C[29];
NewCRC[10] = D[31] ^ D[29] ^ D[28] ^ D[26] ^ D[19] ^ D[16] ^ D[14] ^
D[13] ^ D[9] ^ D[5] ^ D[3] ^ D[2] ^ D[0] ^ C[0] ^ C[2] ^
C[3] ^ C[5] ^ C[9] ^ C[13] ^ C[14] ^ C[16] ^ C[19] ^
C[26] ^ C[28] ^ C[29] ^ C[31];
NewCRC[11] = D[31] ^ D[28] ^ D[27] ^ D[26] ^ D[25] ^ D[24] ^ D[20] ^
D[17] ^ D[16] ^ D[15] ^ D[14] ^ D[12] ^ D[9] ^ D[4] ^
D[3] ^ D[1] ^ D[0] ^ C[0] ^ C[1] ^ C[3] ^ C[4] ^ C[9] ^
C[12] ^ C[14] ^ C[15] ^ C[16] ^ C[17] ^ C[20] ^ C[24] ^
C[25] ^ C[26] ^ C[27] ^ C[28] ^ C[31];
NewCRC[12] = D[31] ^ D[30] ^ D[27] ^ D[24] ^ D[21] ^ D[18] ^ D[17] ^
D[15] ^ D[13] ^ D[12] ^ D[9] ^ D[6] ^ D[5] ^ D[4] ^
D[2] ^ D[1] ^ D[0] ^ C[0] ^ C[1] ^ C[2] ^ C[4] ^ C[5] ^
C[6] ^ C[9] ^ C[12] ^ C[13] ^ C[15] ^ C[17] ^ C[18] ^
C[21] ^ C[24] ^ C[27] ^ C[30] ^ C[31];
NewCRC[13] = D[31] ^ D[28] ^ D[25] ^ D[22] ^ D[19] ^ D[18] ^ D[16] ^
D[14] ^ D[13] ^ D[10] ^ D[7] ^ D[6] ^ D[5] ^ D[3] ^
D[2] ^ D[1] ^ C[1] ^ C[2] ^ C[3] ^ C[5] ^ C[6] ^ C[7] ^
C[10] ^ C[13] ^ C[14] ^ C[16] ^ C[18] ^ C[19] ^ C[22] ^
C[25] ^ C[28] ^ C[31];
NewCRC[14] = D[29] ^ D[26] ^ D[23] ^ D[20] ^ D[19] ^ D[17] ^ D[15] ^
D[14] ^ D[11] ^ D[8] ^ D[7] ^ D[6] ^ D[4] ^ D[3] ^
D[2] ^ C[2] ^ C[3] ^ C[4] ^ C[6] ^ C[7] ^ C[8] ^ C[11] ^
C[14] ^ C[15] ^ C[17] ^ C[19] ^ C[20] ^ C[23] ^ C[26] ^
C[29];
NewCRC[15] = D[30] ^ D[27] ^ D[24] ^ D[21] ^ D[20] ^ D[18] ^ D[16] ^
D[15] ^ D[12] ^ D[9] ^ D[8] ^ D[7] ^ D[5] ^ D[4] ^
D[3] ^ C[3] ^ C[4] ^ C[5] ^ C[7] ^ C[8] ^ C[9] ^ C[12] ^
C[15] ^ C[16] ^ C[18] ^ C[20] ^ C[21] ^ C[24] ^ C[27] ^
C[30];
NewCRC[16] = D[30] ^ D[29] ^ D[26] ^ D[24] ^ D[22] ^ D[21] ^ D[19] ^
D[17] ^ D[13] ^ D[12] ^ D[8] ^ D[5] ^ D[4] ^ D[0] ^
C[0] ^ C[4] ^ C[5] ^ C[8] ^ C[12] ^ C[13] ^ C[17] ^
C[19] ^ C[21] ^ C[22] ^ C[24] ^ C[26] ^ C[29] ^ C[30];
NewCRC[17] = D[31] ^ D[30] ^ D[27] ^ D[25] ^ D[23] ^ D[22] ^ D[20] ^
D[18] ^ D[14] ^ D[13] ^ D[9] ^ D[6] ^ D[5] ^ D[1] ^
C[1] ^ C[5] ^ C[6] ^ C[9] ^ C[13] ^ C[14] ^ C[18] ^
C[20] ^ C[22] ^ C[23] ^ C[25] ^ C[27] ^ C[30] ^ C[31];
NewCRC[18] = D[31] ^ D[28] ^ D[26] ^ D[24] ^ D[23] ^ D[21] ^ D[19] ^
D[15] ^ D[14] ^ D[10] ^ D[7] ^ D[6] ^ D[2] ^ C[2] ^
C[6] ^ C[7] ^ C[10] ^ C[14] ^ C[15] ^ C[19] ^ C[21] ^
C[23] ^ C[24] ^ C[26] ^ C[28] ^ C[31];
NewCRC[19] = D[29] ^ D[27] ^ D[25] ^ D[24] ^ D[22] ^ D[20] ^ D[16] ^
D[15] ^ D[11] ^ D[8] ^ D[7] ^ D[3] ^ C[3] ^ C[7] ^
C[8] ^ C[11] ^ C[15] ^ C[16] ^ C[20] ^ C[22] ^ C[24] ^
C[25] ^ C[27] ^ C[29];
NewCRC[20] = D[30] ^ D[28] ^ D[26] ^ D[25] ^ D[23] ^ D[21] ^ D[17] ^
D[16] ^ D[12] ^ D[9] ^ D[8] ^ D[4] ^ C[4] ^ C[8] ^
C[9] ^ C[12] ^ C[16] ^ C[17] ^ C[21] ^ C[23] ^ C[25] ^
C[26] ^ C[28] ^ C[30];
NewCRC[21] = D[31] ^ D[29] ^ D[27] ^ D[26] ^ D[24] ^ D[22] ^ D[18] ^
D[17] ^ D[13] ^ D[10] ^ D[9] ^ D[5] ^ C[5] ^ C[9] ^
C[10] ^ C[13] ^ C[17] ^ C[18] ^ C[22] ^ C[24] ^ C[26] ^
C[27] ^ C[29] ^ C[31];
NewCRC[22] = D[31] ^ D[29] ^ D[27] ^ D[26] ^ D[24] ^ D[23] ^ D[19] ^
D[18] ^ D[16] ^ D[14] ^ D[12] ^ D[11] ^ D[9] ^ D[0] ^
C[0] ^ C[9] ^ C[11] ^ C[12] ^ C[14] ^ C[16] ^ C[18] ^
C[19] ^ C[23] ^ C[24] ^ C[26] ^ C[27] ^ C[29] ^ C[31];
NewCRC[23] = D[31] ^ D[29] ^ D[27] ^ D[26] ^ D[20] ^ D[19] ^ D[17] ^
D[16] ^ D[15] ^ D[13] ^ D[9] ^ D[6] ^ D[1] ^ D[0] ^
C[0] ^ C[1] ^ C[6] ^ C[9] ^ C[13] ^ C[15] ^ C[16] ^
C[17] ^ C[19] ^ C[20] ^ C[26] ^ C[27] ^ C[29] ^ C[31];
NewCRC[24] = D[30] ^ D[28] ^ D[27] ^ D[21] ^ D[20] ^ D[18] ^ D[17] ^
D[16] ^ D[14] ^ D[10] ^ D[7] ^ D[2] ^ D[1] ^ C[1] ^
C[2] ^ C[7] ^ C[10] ^ C[14] ^ C[16] ^ C[17] ^ C[18] ^
C[20] ^ C[21] ^ C[27] ^ C[28] ^ C[30];
NewCRC[25] = D[31] ^ D[29] ^ D[28] ^ D[22] ^ D[21] ^ D[19] ^ D[18] ^
D[17] ^ D[15] ^ D[11] ^ D[8] ^ D[3] ^ D[2] ^ C[2] ^
C[3] ^ C[8] ^ C[11] ^ C[15] ^ C[17] ^ C[18] ^ C[19] ^
C[21] ^ C[22] ^ C[28] ^ C[29] ^ C[31];
NewCRC[26] = D[31] ^ D[28] ^ D[26] ^ D[25] ^ D[24] ^ D[23] ^ D[22] ^
D[20] ^ D[19] ^ D[18] ^ D[10] ^ D[6] ^ D[4] ^ D[3] ^
D[0] ^ C[0] ^ C[3] ^ C[4] ^ C[6] ^ C[10] ^ C[18] ^
C[19] ^ C[20] ^ C[22] ^ C[23] ^ C[24] ^ C[25] ^ C[26] ^
C[28] ^ C[31];
NewCRC[27] = D[29] ^ D[27] ^ D[26] ^ D[25] ^ D[24] ^ D[23] ^ D[21] ^
D[20] ^ D[19] ^ D[11] ^ D[7] ^ D[5] ^ D[4] ^ D[1] ^
C[1] ^ C[4] ^ C[5] ^ C[7] ^ C[11] ^ C[19] ^ C[20] ^
C[21] ^ C[23] ^ C[24] ^ C[25] ^ C[26] ^ C[27] ^ C[29];
NewCRC[28] = D[30] ^ D[28] ^ D[27] ^ D[26] ^ D[25] ^ D[24] ^ D[22] ^
D[21] ^ D[20] ^ D[12] ^ D[8] ^ D[6] ^ D[5] ^ D[2] ^
C[2] ^ C[5] ^ C[6] ^ C[8] ^ C[12] ^ C[20] ^ C[21] ^
C[22] ^ C[24] ^ C[25] ^ C[26] ^ C[27] ^ C[28] ^ C[30];
NewCRC[29] = D[31] ^ D[29] ^ D[28] ^ D[27] ^ D[26] ^ D[25] ^ D[23] ^
D[22] ^ D[21] ^ D[13] ^ D[9] ^ D[7] ^ D[6] ^ D[3] ^
C[3] ^ C[6] ^ C[7] ^ C[9] ^ C[13] ^ C[21] ^ C[22] ^
C[23] ^ C[25] ^ C[26] ^ C[27] ^ C[28] ^ C[29] ^ C[31];
NewCRC[30] = D[30] ^ D[29] ^ D[28] ^ D[27] ^ D[26] ^ D[24] ^ D[23] ^
D[22] ^ D[14] ^ D[10] ^ D[8] ^ D[7] ^ D[4] ^ C[4] ^
C[7] ^ C[8] ^ C[10] ^ C[14] ^ C[22] ^ C[23] ^ C[24] ^
C[26] ^ C[27] ^ C[28] ^ C[29] ^ C[30];
NewCRC[31] = D[31] ^ D[30] ^ D[29] ^ D[28] ^ D[27] ^ D[25] ^ D[24] ^
D[23] ^ D[15] ^ D[11] ^ D[9] ^ D[8] ^ D[5] ^ C[5] ^
C[8] ^ C[9] ^ C[11] ^ C[15] ^ C[23] ^ C[24] ^ C[25] ^
C[27] ^ C[28] ^ C[29] ^ C[30] ^ C[31];
nextCRC32_D32 = NewCRC;
end
endfunction
endmodule
Re: Depending on CRC polynomial....How are new values calcul
Ii is very easy. It is according to CRC-32 polynomial. you can draw LFSR strtucture according to the CRC-32 poly with data input on MSB i.e x^31.
if you wont get tell me..i will explain you in detail
Hi Chiru....
Can you expalin me in Detail....
I mean how the numbers..D[31],D[29].....in each bit calculation and other bits used in other calculation...are taken
Thanks
Generate function CRC32_D1 i.e. for one bit data.
Here is it:
NewCRC(0) := D(0) xor C(31);
NewCRC(1) := D(0) xor C(0) xor C(31);
NewCRC(2) := D(0) xor C(1) xor C(31);
NewCRC(3) := C(2);
NewCRC(4) := D(0) xor C(3) xor C(31);
NewCRC(5) := D(0) xor C(4) xor C(31);
NewCRC(6) := C(5);
NewCRC(7) := D(0) xor C(6) xor C(31);
NewCRC(8) := D(0) xor C(7) xor C(31);
NewCRC(9) := C(8);
NewCRC(10) := D(0) xor C(9) xor C(31);
NewCRC(11) := D(0) xor C(10) xor C(31);
NewCRC(12) := D(0) xor C(11) xor C(31);
NewCRC(13) := C(12);
NewCRC(14) := C(13);
NewCRC(15) := C(14);
NewCRC(16) := D(0) xor C(15) xor C(31);
NewCRC(17) := C(16);
NewCRC(18) := C(17);
NewCRC(19) := C(18);
NewCRC(20) := C(19);
NewCRC(21) := C(20);
NewCRC(22) := D(0) xor C(21) xor C(31);
NewCRC(23) := D(0) xor C(22) xor C(31);
NewCRC(24) := C(23);
NewCRC(25) := C(24);
NewCRC(26) := D(0) xor C(25) xor C(31);
NewCRC(27) := C(26);
NewCRC(28) := C(27);
NewCRC(29) := C(28);
NewCRC(30) := C(29);
NewCRC(31) := C(30);
Say for second bit D(1),Newcrc(1) looks like
Newcrc(1) :- D(1) xor D(0) xor C(0) xor C(31);
Similarly ,u have to iterate for D(2),D(3),…..D(31) for 32 bits data.
