ShareHing
- Joined
- Feb 8, 2014
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 46
Hadn't turned this one On in a couple of months. Picked it up again, fixed the broken antenna connector...connected an AM loop antenna... worked for 15min and it turned itself off.
The male connector already had the central prong broken when I found this unit in the trash. Today I removed the rest with the Dremel and soldered another prong.
I only had an AM loop antenna around but connected it anyway like this:
I dont know if this might have caused the damage or not. The unit worked perfectly for 15min (finally had FM reception) but just shut down and it doesnt turn on anymore.
Havent tested anything with the multimeter yet. I'd just like to ask first if the incorrect use of antennas might have been the problem.
Here is teh service manual:
https://www.google.com/url?sa=t&rct...r1rWjbWi9txosrA&bvm=bv.77161500,d.d2s&cad=rja
https://docs.google.com/file/d/0B6fu025jFteZaHAzZHVndDlWdUk/edit?pli=1
https://www.hifiengine.com/manual_library/denon/dra-345r.shtml
