Delay in 89c51 using C in keil
jay_3189
Banned
Full Member level 1
Ahmedabad
I am using 89c51 controller and crystal frequency of 11.0592mhz and using c language to create delay loop. I wanted to know that delay_us(), delay_ms() and delay_sec() are by default function of this controller or I have to create it on my own way.
if its by default then ow could I use it and if not then please verify bellowed one.. is that right one.
and can I use this loop delay for using I2C communication for DS1307 RTC.
HTML:
/*It genarates a approximate delay of 10us for each count,
if 5000 is passed as the argument then it generates a delay of apprx 50ms.*/
void delay_us(unsigned int us_count)
	while(us_count!=0)
		us_count--;
/*It genarates a approximate delay of 1ms for each count,
if 1000 is passed as the argument then it generates delay of apprx 1000ms(1sec)*/
void delay_ms(unsigned int ms_count)
	while(ms_count!=0)
		delay_us(112);   //delay_us is called to generate 1ms delay
		ms_count--;
/*It genarates a approximate delay of 1sec for each count,
if 10 is passed as the argument then it generates delay of apprx 10sec
note: A max of 255 sec delay can be generated using this function.*/
void delay_sec(unsigned char sec_count)
	while(sec_count!=0)
		delay_ms(1000); //delay_ms is called to generate 1sec delay
		sec_count--;
several way to create delay function . but best way is using _nop_() instruction and count cycle using stop watch to get better result .
as per your mean below code right?
will that give 1us delay in keil?
while(us_count!=0)
_nop_();
us_count--;
in my 89c51rd2 and crystal 11.0592 delay for 1 microsecond is below
void DelayMicro (int us)
      for( ; us > 0 ; us--)
             _nop_();
             _nop_();
             _nop_();
             _nop_();
and 1 mSec
void DelayMs (int  mS)
      unsigned int a ;
      unsigned char b ;
      for(a = 0 ; a < mS ; a++)
          for(b = 0 ; b < 190 ; b++)
                 _nop_();
                 _nop_();
             _nop_();
             _nop_();
             _nop_();
             _nop_();
and 1 mSec
      unsigned int a ;
      unsigned char b ;
                 _nop_();
                 _nop_();
how do you calculate this?
can you give me for 1 sec for 11.0592MHz...
For small delays, such as around few micro seconds, no problem.
However, for somewhat on magnitude of mili seconds and higher, this implementation waste excessive computer processing of the microcontroler.
On that circumstances, is better suitable employ time slot approach, interrupt driven, in order to release overall program processing.
I got you. my project is also same that I have to keep delay more then an hour also or for few hours as per user requirement. (I mean by interrupt I have to take data from user for to which pin to automate of controller)
can you help me to get idea to complete this.
I am using AT89C51.
ya bro u are absolutely right and i agree with u.
             _nop_();
             _nop_();
             _nop_();
             _nop_();
and 1 mSec
      unsigned int a ;
      unsigned char b ;
                 _nop_();
                 _nop_();
I have cheked this code for DelayMS(1000) but its not working for 1 sec for 11.0592MHz.
ok then now try to some calculation clear . you have to calculate the time taken for the cycle execution if the frequency is 11.0592MHz. 8051 uses 1/12 of oscilator frequency, So now frequency is 921.6kHz
Now Cycle execution time becomes 1/f = 1/921.6kHz = 1.085uS
now your Total Cycles * 1.085uS = your desired time.
and also using timer read thread may be helpful
but i think if you are using assembly then you can multiply no of cycle with 1.085 to find desired delay.
but in terms of C it is not true. bcoz compiler convert the code to the assembly so we cannot judge one for loop for 1 instruction.
for loop get convert it into assembly with big code.
...I have to keep delay more then an hour also or for few hours...can you help me to get idea to complete this...
I don´t think that generating timing without applying an external RTC on project would work properly.
If you achieve for instance 1s through internal Timer, is associated some error, which would be multiplied when calculating some hours.
Take a look on some examples bellow :
I already did that on other core with DS1307 RTC using C language, and it is extremely easy, due this device can be configured to generate a precise 1s at output pin which can be read from microcontroler through I/O interrupt routine.
Check if this helps you: https://www.edaboard.com/threads/225009/#post959855
I seen the link given by you but that I have seen before also but there I am getting many errors.
as you have said you have work on DS1307 with 89c51 then please see below link and help me if you could solve the mistakes.
https://www.edaboard.com/threads/305721/
