[SOLVED] Delay and config question in MPlad coding
WhyWhy
Member level 4
Member level 4
Hi guys,
i just wondering why the delay 1 second is "for(i=0;i<30000;i++)",but not "for(i=0;i<1;i++)". And the config why should be __CONFIG(0X3F38)?
regards,
YY
That is because, the single instruction gets executed in a fraction of milliseconds based on the clock speed and not in seconds...
i think u must read carefully datasheet because datasheet give u so many solution to just try and put your code to implement . configuration is the more important part of any micro controller mostly in world of PIC.
Reactions: WhyWhy
    WhyWhy
Hi Vengateswaran and nick703,
Thanks for your helps.
Regards,
YY
Regards,
YY
most of the time delay routines are built in compiler and need to include.
