nodee
Junior Member level 3
Electromagnet - Remove magnetic remanence
I have circuit that uses a electromagnet (holds about 50kg) to hold a door closed, the circuit is powered by 24V. The electromagnet is energised via a high side driver using a p-channel MOSFET connected to one terminal of the electromagnet and the other terminal to 0V.
The problem I have is that the door is not released once the electromagnet is powered down, instead some magnetic remanence holds the door closed with about 15kg of force.
I've looked online to find a solution and the suggestion of a LC tank (non-polarised capacitor in parallel with electromagnet) that creates a exponentially decaying oscillation when power is removed that will degauss the electromagnet. If I power up then down with the door open (no plate on the face of the electromagnet) I can see the waveform on my scope as described, If I have the door closed (plate on the face of the magenet) however the effect is gone.
Any suggestions at what is happening or a possible solution?
Thanks,
nodee
Thanks,
nodee
