huynguyenle
Newbie level 3
- Joined
- Mar 26, 2015
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 22
Dear all,
I'm creating a schematic to simulate and measure Fanout-Of-h delay using Cadence Virtuoso.
What I want to do is to define the number of instances of a particular inverter as a parameter (hence I can use parametric analysis to evaluate the change of delay with respect to the change of fanout).
As far as I know, there are two ways to change the number of instances of a component in Cadence schematic:
+ Using the m-factor
+ Using the I1<0:3> to instantiate 4 similar I1 components.
However, in both ways I tried but failed to set a parameter for the number of instances.
For example, when I defined I1<0:h> then Schematic told me that an error occurred in my circuit.
If someone had a same problem and knew how to fix it, I would be very thankful to have your instructions.
Thanks, everyone!
Thanks, everyone!
