Deep N-well Depletion Regions
mult
Junior Member level 1
Hello there,
could anybody tell me, what happens if two depletion regions of deep N-wells reach each other?
Thanks in advance!
dick_freebird
Advanced Member level 7
USA
In a FET, BJT or diode the reach-through is onset of early breakdown. But I have never noticed a more general description (though any 3-region device could be considered a transistor of some, possibly degenerate sort)..A difference might be that transistors / diodes tend to be biased with different terminal voltages while (say) two closely spaced Newell regions might have zero potential difference and then zero outcome.
timof
Advanced Member level 3
San Jose, CA, USA
When two depletion regions (n-p and p-n) merge, you do not have a quasi-neutral p region (that has a high potential barrier for electrons), it becomes fully depleted. The barrier becomes dramatically lower, which may increase exponentially the leakage (current) between the n regions. This condition is often called punch-through.
