Raj Sohal
Newbie level 1
- Joined
- Dec 6, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 55
I am in the process of writing a code to decode the DCF signal. I keep getting an error
Here is my code below, it is long. Any help would be greatly appreciated.
I am unsure how to solve this as it simulates fine and outputs the correct graph, but the synthesizing gives this error.WARNING:Xst:2935 - Signal 'year<3>', unconnected in block 'dcf_decode', is tied to its initial value (0010).
WARNING:Xst:2935 - Signal 'year<2>', unconnected in block 'dcf_decode', is tied to its initial value (0000).
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; use WORK.util.all; entity dcf_decode is generic ( clk_freq: positive := 125000000; -- Hz gate_delay: time := 1 ns ); port ( rst: in std_logic := 'X'; -- reset clk: in std_logic := 'X'; -- clock si: in std_logic := 'X'; -- start of second in mi: in std_logic := 'X'; -- start of minute in bi: in std_logic := 'X'; -- bit in year: out bcd_digit_vector(3 downto 0) := (3 => bcd_two, 2 => bcd_zero, others => bcd_minus); month: out bcd_digit_vector(1 downto 0) := (others => bcd_minus); day: out bcd_digit_vector(1 downto 0) := (others => bcd_minus); hour: out bcd_digit_vector(1 downto 0) := (others => bcd_minus); minute: out bcd_digit_vector(1 downto 0) := (others => bcd_minus); second: out bcd_digit_vector(1 downto 0) := (others => bcd_zero); tr: out std_logic := '0' -- new bit trigger ); end dcf_decode; architecture rtl of dcf_decode is type states is (start,data_out,hold_delay,trig_rst); constant one_min : natural := 60; signal state: states := start; signal nxt_state: states := start; signal output: bcd_digit_vector(9 downto 0) := (others=> bcd_minus); -- Avoid latching signal output_nxt: bcd_digit_vector(9 downto 0) := (others=> bcd_minus); signal sec_unit: unsigned((n_bits(9) - 1 ) downto 0) := (others => '0'); -- Seconds units signal sec_tenth: unsigned((n_bits(9) - 1 ) downto 0) := (others => '0'); -- Seconds tenth signal sec_unit_nxt: unsigned((n_bits(9) - 1 ) downto 0) := (others => '0'); signal sec_tenth_nxt: unsigned((n_bits(9) - 1 ) downto 0) := (others => '0'); signal cnt : unsigned((n_bits(one_min) - 1) downto 0) := (others => '0'); -- Declare a counter to populate array signal nxt_cnt : unsigned((n_bits(one_min) -1) downto 0) := (others => '0'); -- Next counter signal bit_array : unsigned(59 downto 0) := (others => 'X'); -- Array to store values signal bit_array_nxt: unsigned(59 downto 0) := (others => 'X'); -- Array to store values shared variable x: integer := 0; -- Counter shared variable nxt_x: integer := 0; begin process (rst, clk) begin if (rst = '1') then cnt <= (others => '0'); state <= start; elsif clk'event and (clk = '1') then cnt <= nxt_cnt; state <= nxt_state; sec_unit<= sec_unit_nxt; sec_tenth <= sec_tenth_nxt; bit_array <= bit_array_nxt; output <= output_nxt; x := nxt_x; end if; end process; process(si,mi,bi,cnt,state, bit_array, sec_unit,sec_tenth,output) begin nxt_cnt <= cnt; nxt_state <= state; tr <= '0'; -- Reset the bit trigger after every clock cycle sec_tenth_nxt <= sec_tenth; sec_unit_nxt <= sec_unit; bit_array_nxt <= bit_array; output_nxt<= output; nxt_x := x; case state is when start => -- Waiting to recieve a second pulse bit_array_nxt(x) <= bi; if(si = '1' and mi = '0') then -- Second input high and min input high if(sec_unit < 9) then sec_unit_nxt <= sec_unit + 1; else sec_unit_nxt <= (others => '0'); sec_tenth_nxt <= sec_tenth + 1; end if; nxt_x := x + 1; nxt_state <= hold_delay; elsif(si = '1' and mi = '1') then -- Second input high and min input high nxt_state <= hold_delay; -- Go state three sec_tenth_nxt <= (others => '0'); -- Reset sec_unit_nxt <= (others => '0'); -- Reset nxt_x := 0; elsif (x = 59) then -- When counter equal 59 nxt_state <= data_out; -- Go state 2 end if; when data_out => if (sec_unit=9 and sec_tenth=5) then if((bit_array(28) xor bit_array(27) xor bit_array(26) xor bit_array(25) xor bit_array(24) xor bit_array(23) xor bit_array(22) xor bit_array(21)) = '0') then --Parity check for min output_nxt(0) <= bit_array(24) & bit_array(23) & bit_array(22) & bit_array(21); -- Unit min value output_nxt(1) <= '0' & bit_array(27) & bit_array(26) & bit_array(25); -- Tenth min value else output_nxt(0) <= bcd_error; output_nxt(1) <= bcd_error; end if; if((bit_array(35) xor bit_array(34) xor bit_array(33) xor bit_array(32) xor bit_array(31) xor bit_array(30) xor bit_array(29)) = '0') then --Parity check for hour output_nxt(2) <= bit_array(32) & bit_array (31) & bit_array(30) & bit_array(29); -- Unit hour value output_nxt(3) <= "00" & bit_array(34) & bit_array(33); -- Tenth hour value else output_nxt(2) <= bcd_error; output_nxt(3) <= bcd_error; end if; if((bit_array(58) xor bit_array(57) xor bit_array(56) xor bit_array(55) xor bit_array(54) xor bit_array(53) xor bit_array(52) xor bit_array(51) xor bit_array(50) xor bit_array(49) xor bit_array(48) xor bit_array(47) xor bit_array(46) xor bit_array(45) xor bit_array(44) xor bit_array(43) xor bit_array(42) xor bit_array(41) xor bit_array(40) xor bit_array(39) xor bit_array(38) xor bit_array(37) xor bit_array(36)) = '0') then --Parity check for date output_nxt(4) <= bit_array(39) & bit_array(38) & bit_array(37) & bit_array(36); output_nxt(5) <= "00" & bit_array(41) & bit_array(40); output_nxt(6) <= bit_array(48) & bit_array(47) & bit_array(46) & bit_array(45); output_nxt(7) <= "000" & bit_array(49); output_nxt(8) <= bit_array(53) & bit_array(52) & bit_array(51) & bit_array(50); output_nxt(9) <= bit_array(57) & bit_array(56) & bit_array(55) & bit_array(54); else output_nxt(4) <= bcd_error; output_nxt(5) <= bcd_error; output_nxt(6) <= bcd_error; output_nxt(7) <= bcd_error; output_nxt(8) <= bcd_error; output_nxt(9) <= bcd_error; end if; sec_tenth_nxt <= (others => '0'); sec_unit_nxt <= (others => '0'); nxt_x := 0; nxt_state <= start; else sec_tenth_nxt <= (others => '0'); sec_unit_nxt <= (others => '0'); nxt_x := 0; nxt_state <= start; -- Switch the state back to start end if; when hold_delay => nxt_state <= trig_rst; when trig_rst =>tr <= '1'; nxt_state <= start; end case; end process; second(0) <= sec_unit; second(1) <= sec_tenth; minute(0) <= output(0); minute(1) <= output(1); hour(0) <= output(2); hour(1) <= output(3); day(0) <= output(4); day(1) <= output(5); month(0) <= output(6); month(1) <= output(7); year(0) <= output(8); year(1) <= output(9); end rtl;
