shashankbr
Junior Member level 1
Hi everyone,
I have an Altec Lansing FX5051 Home Theatre System.
Recently the unit stopped working and when I checked it, the fuse on PCB was burnt. After I replaced the fuse, I checked for PCB errors.
Design of PCB
- 240v to 18.5 V 5.4 A step down transformer which connects to a bridge rectifier IC on PCB through fuse.
The errors i found were - The +ve and -ve outputs of the rectifier were shorted. Hence the fuse blew up. So I removed the rectifier and found that its working fine.
Then when I checked on the PCB, the traces of +ve & -ve supply were shorted.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The PCB has lots of components on it. (Actually am amplifier + 5 channel sound card )
Question : Is there a way to find out which component of the PCB is burnt i.e the component which is causing the short?
Thanks all
Design of PCB
Thanks all
