howlad
Newbie level 2
Hey all,
I am currently trying to design a step-up converter for an autonomious fuel cell system. It has to suffice the following demands:
Vin, min = 4 V
Vin, max = 8 V
Vout = 12 V
Iout = min 2 A
Since a fuel cell has its peak current at lowest voltage, the converter has to be able to deliver 12 V / 2 A at 4 V input voltage (and approx. 8 A). The fuel cell stack is rated at 50 W but it's very old, the realistic maximum power is about 30 -35 W. The output power (and thus the output current) should be as high as possible. Assuming an efficiency of about 80%, the output current should be around 2 amps...
I've already designed a working converter as a first step (using the Maxim MAX 1771 -> ) but that one has a maximum ouput current of 0.5 A.
Does anyone know a converter I could use?
Many thanks in advance,
Steve
Vin, min = 4 V
Vin, max = 8 V
Vout = 12 V
Iout = min 2 A
Steve
