Rajnaveen
Member level 2
Hi
I am using op amp as an amplifier to amplify a mV signal sensed through a shunt resistance in a solar charger that is integrated with a 5000W inverter . my problem is that when i run load at inverter there is some off set voltage at op amp due to ground difference . how to resolve the issue
