Data transmission serially by 8051 through rf module.
tapu
Full Member level 4
india
Data transmition serielly by by 8051 through rf module.
Dear All,
I want to transmit data serielly by using Rf module 433mhz.I have made circuit as follow in proteus.As i press key in transmitter side then data is not seen in reciever 8051 port.pls chk & help.
Thks,
Tepu
Transmitter code:
//-----------------Program for wireless Home Automation using cheap ass 413MHz RF module
//-----------------Target controller family: 8051 <works for any 8051 family with minimal or no modifications>
//-----------------Programmer: Moses Okoroafor
//-----------------Company: Pearl Electronics Nigeria.
//-----------------Date started: 27/04/2017
#define OFF 1
#define ON  0
#include <REGx051.H>
 //-----------PORT TO VARIABLE ASSIGNMENT--------------------------
sbit BUT1 = P3^2;
sbit BUT2 = P3^3;
sbit BUT3 = P3^7;
sbit LED1 = P3^5;
sbit LED2 = P3^4;
//-------------PROTOTYPE DECLARATION-------------------------------
void delay(unsigned int ms);
void UART_Init();
void UART_TxChar(char ch);
void transmit(int datum);
bit i,j,k;
//-------------MAIN PROGRAM STARTS HERE----------------------------
void main()
	i = j = k = 1;
	EA = 0;
	P1 = 0X3F; P3 = 0XFF;                    // shows '0' on the 7 seg on startup
	delay(300);
	LED1 = LED2 = ON;
	delay(1000);
	LED1 = LED2 = OFF;
	delay(100);
	UART_Init();
	while(1)
 if (!BUT1)                                           //button for one light
    {delay(30);
      if(!BUT1)
				j = ~j;
				if(j==0)
       { transmit(0x01); LED1 = ON;  if(k==0) P1 = 0X5b; else P1 = 0x06;}               //when bits are 0, lights come ON
				 else {transmit(0x09);LED1 = OFF; if(k==1)P1 = 0X3F; else P1 = 0x06;}
				delay(300);
if (!BUT2)                                           //button for the second light
    {delay(30);
      if(!BUT2)
				k = ~k;
				if(k==0)    {transmit(0x03); LED2 = ON; if(j==0)P1 = 0X5B; else P1 = 0X06;}                          //lights ON
				else     {transmit(0x06); LED2 = OFF;   if(j==0)P1 = 0x06; else P1 = 0X3F;}
				delay(300);
if (!BUT3)                                         // reset
    {delay(30);
      if(!BUT3)
				i = ~i;
				if(i==0) {transmit(0x02); LED1 = LED2 = ON; }
				else     {transmit(0x0F); LED1 = LED2 = OFF;}
				delay(300);
//---------------FUNCTION BODY DEFINITION--------------------------------------
void delay(unsigned int ms){                      //generate one millisecond delay
  unsigned int i,j;
  for	(i=0; i<ms; i++)
  for   (j=0; j<=120; j++);}
	void UART_Init(){
	TMOD |= 0X20;                       // Timer 1 in mode 2
	TH1=-24;                            // Baud rate of 1200
	SCON = 0X50;                         //Asynchronous 8-bit data
	TR1 = 1;                             // Turn ON the timer
  void UART_TxChar(char ch){
	SBUF=ch;           // Load transmitted data to be transmitted.
	while(TI==0);      // Wait till data is transmitted
	TI=0;              //Clear the transmit flag.
void transmit(int datum){
	int i = 0;
	int start  =  0x55;             // Create a variable name START
	int addr   =  0x8E;              //  Create a variable name ADDR
	int chksum =  (addr+datum);            //   Create a variable name CHKSUM
		for (; i<5; i++)
		UART_TxChar(start);           // Transmit the content of START
		UART_TxChar(datum);           // Transmit DATUM
		UART_TxChar(addr);            //Transmit ADDR
		UART_TxChar(chksum);          // Transmit CHKSUM
		delay(2);                      //2ms delay
Reciever code:
#define OFF 1
#define ON  0
#include <REGX52.H>
sbit LED1 = P1^0;
sbit LED2 = P1^1;
void UART_Init();
char UART_RxChar();
void receive();
void main()
		LED1 = LED2 = ON;
	delay(1000);
	LED1 = LED2 = OFF;
	delay(100);
	UART_Init();
	while(1)
		receive();
//---------------DEFINITION OF FUNCTIONS----------------------------------
  unsigned int i,j;
void UART_Init(){
	char UART_RxChar()
	char ch;
	while(RI==0);
	ch = SBUF;
  	RI=0;
	  return(ch);             // Return the received character.
 void receive()                   //   Receive procedures
int start;	 	// create variable named start
int addr;   	// create variable named addr
int datum;		// create variable named datum
int chksum; 	// create variable named chksum
while(1)               // Do an infinite loop
    { start = UART_RxChar();        			// Store received UART byte into the variable "start"
	if (start == 0x55)                      // if start is equal to 0x55 , Start Byte
		 SBUF =0;                              //clear SBUF
		 datum = UART_RxChar();			          //Next received byte becomes the data
		 addr = UART_RxChar();               // Store received UART byte into the variable "addr"
		chksum = UART_RxChar();
			if (chksum == (datum+addr))                //if chksum is equal to datum+addr then
				switch(datum)
						case (0x01):  { LED1 = ON; }         break;
						case (0x02):  { LED1 = LED2 = ON;}   break;
						case (0x03):  { LED2 = OFF;}         break;
					  case (0x0F):  { LED1 = LED2 = OFF;}  break;
						case (0x09):  { LED1 = OFF; }        break;
            case (0x06):  { LED2 = ON; }         break;
					}                                  //endif for switch statement
			}                                     //endif
		}                                      //endif
Re: Data transmition serielly by by 8051 through rf module.
Didn't you note that you have not implemented the receive() function at the receive side ?
You have just the prototype and the the function called at the main, nothing else.
I could'nt attach complete code.As i copy & paste full code???
Click on "Go Advanced" button, right below the "Quick Reply" panel.
There you can find option to attach compressed files.
Thank you for reply.Here is my code.
  • Rf com.rar
