melexia
Member level 2
Hi all
I am using EDK 11.1. I have generated a TEMAC core in ISE using core generator, wrote some VHDL code to handle data packets. I have added this TEMAC core to my xmp project i.e. microblaze as a custom IP through PLB. Now my aim is to write data from microblaze to custom IP so that it will take it as data and use that data for transfer. Also whatever data is received back should get written back to microblaze through PLB only and saved inside microblaze.
I believe that as a specific memory space is allotted to custom IP whatever I am expecting it to do i.e. above mentioned is possible.
Am I going wrong somewhere.
Is it like as custom IP in this case will act as slave and hence it can not write some 1 k of data bytes back to PLB.
Please suggest if there is some other easier way to perform this task.
thanks and regards
thanks and regards
