HelloWorld*ImLost
Newbie level 1
[HELP ] Data colection -AX-11 microcontroller -Interactive C
Hi Guys, I hope some one can help me out because I have reached as far as I could alone…
I have an Inex Interactive C Robot Kit which is composed of a “AX-11 microcontroller board is a modified version of the popular Handy board from MIT”.
My current project is to read and record 2 sensors and export the readings/measurements into excel, while one of the sensor controls the motor speed. [simple right?
My difficulty at the moment is to record and export the data to a PC. I have been reading and due to the lack of memory the only way is to export the data via the data cable. However I have not managed to do this. I have been trying to follow the instructions on LINK + click Data Collection , however it seems that they have forgotten to put the conversion code to convert the data on the PC side, as they wrote “The code to do the conversion can be found here” and the HERE is not a click/link button.
Even though I have included the code on the link above on my program, I’m not getting or I don’t know where I am supposed to see/open the data coming from the board/sensors.
If some one could shine a light I would be deeply grateful.
feel free to say that I doing something wrong, but please tell me how to fix it
My code (or my attempt of writing the program);
Thank you in advance!
/* GP2D120 test*/
Hardware configuration*/
#define base -19
#define pow 80
float dis_table[118]=
{ /*distance value*//*ADC value*/
32.0,/*19*/ 30.1,/*20*/ 29.5,/*21*/ 28.6,/*22*/ 27.5,/*23*/
26.1,/*24*/ 25.3,/*25*/ 24.5,/*26*/ 23.7,/*27*/ 23.2,/*28*/
22.3,/*29*/ 22.0,/*30*/ 21.1,/*31*/ 20.5,/*32*/ 20.0,/*33*/
19.3,/*34*/ 19.1,/*35*/ 18.4,/*36*/ 17.9,/*37*/ 17.5,/*38*/
17.1,/*39*/ 16.5,/*40*/ 16.2,/*41*/ 15.8,/*42*/ 15.6,/*43*/
15.5,/*44*/ 15.3,/*45*/ 14.8,/*46*/ 14.2,/*47*/ 13.8,/*48*/
13.6,/*49*/ 13.3,/*50*/ 13.1,/*51*/ 12.8,/*52*/ 12.6,/*53*/
12.4,/*54*/ 12.2,/*55*/ 12.0,/*56*/ 11.8,/*57*/ 11.7,/*58*/
11.6,/*59*/ 11.6,/*60*/ 11.5,/*61*/ 11.4,/*62*/ 11.3,/*63*/
10.85,/*64*/ 10.6,/*65*/ 10.3,/*66*/ 10.2,/*67*/ 10.0,/*68*/
9.8,/*69*/ 9.7,/*70*/ 9.5,/*71*/ 9.3,/*72*/ 9.2,/*73*/
9.0,/*74*/ 8.9,/*75*/ 8.8,/*76*/ 8.6,/*77*/ 8.4,/*78*/
8.3,/*79*/ 8.2,/*80*/ 8.0,/*81*/ 7.85,/*82*/ 7.7,/*83*/
7.6,/*84*/ 7.5,/*85*/ 7.3,/*86*/ 7.2,/*87*/ 7.15,/*88*/
7.1,/*89*/ 7.0,/*90*/ 6.9,/*91*/ 6.8,/*92*/ 6.7,/*93*/
6.6,/*94*/ 6.5,/*95*/ 6.4,/*96*/ 6.35,/*97*/ 6.3,/*98*/
6.2,/*99*/ 6.15,/*100*/ 6.1,/*101*/ 6.0,/*102*/ 5.9,/*103*/
5.85,/*104*/ 5.8,/*105*/ 5.7,/*106*/ 5.65,/*107*/ 5.6,/*108*/
5.55,/*109*/ 5.45,/*110*/ 5.4,/*111*/ 5.4,/*112*/ 5.3,/*113*/
5.2,/*114*/ 5.1,/*115*/ 5.0,/*116*/ 5.0,/*117*/ 4.9,/*118*/
4.9,/*119*/ 4.8,/*120*/ 4.8,/*121*/ 4.7,/*122*/ 4.7,/*123*/
4.6,/*124*/ 4.6,/*125*/ 4.5,/*126*/ 4.5,/*127*/ 4.4,/*128*/
4.4,/*129*/ 4.3,/*130*/ 4.3,/*131*/ 4.2,/*132*/ 4.2,/*133*/
4.1,/*134*/ 4.1,/*135*/ 4.0/*136*/
void serial_putchar(int c)
while (!(peek(0x102e) & 0x80)); /* wait until serial transmit empty */
poke(0x102f, c); /* send character */
/* necessary to receive characters using serial_getchar */
void disable_pcode_serial()
poke(0x3c, 1);
/* necessary for IC to interact with board again */
void reenable_pcode_serial()
poke(0x3c, 0);
/* wait for received character */
int serial_getchar(int c)
while (!(peek(0x102e) & 0x20));
return peek(0x102f);
// sendIntAsAscii
// Convert integers to ascii and then prints them out on LCD
void main()
int an; // Keep analog value from sensor
int value; // Declare keep input from touch sensor
ao(); // All Motors off
while(!stop_button()) // wait STOP button pressed in process
printf("Press start!\n"); // Show begining message
while(!start_button()); // Wait START button pressed to run
while(!stop_button()) // Wait STOP button pressed in process
an = analog(6); // Read analog value from sensor
value = analog(4); // Keep value from AI-4 channel
if (an>=19 && an<=50) // distance far away
motor(0,pow); // Motor0 forward at Pow of maximum power
motor(1,pow); // Motor1 forward at Pow value
printf("Range cm =%f Light= %d\n",dis_table[an+base],value); // Show distance value & light value
serial_putchar(value); // trying to send the data value to the pc
serial_putchar(an); // trying to send the data value to the pc
else if (an>=51 && an<=136) //distance far away close
motor(0,pow/2); // Motor0 forward at 40% of maximum power
motor(1,pow/2); // Motor1 forward at 40% of maximum power
else
motor(0,00); // Motor0 forward at 0% of maximum power
motor(1,00); // Motor1 forward at 0% of maximum power
printf("Out of Range! Light= %d\n",value); // Show message out of Range
sleep(0.4); // Delay before read new cycle
printf("Stop...\n"); // Show finish message
ao(); // Off all motor for ending program
beep(); // Sound beep for ending program
sleep(1.5); // Delay before read new cycle
