[SOLVED] DAC waveform generation in LTSpice
neddie
Full Member level 5
Full Member level 5
South Africa
Does anybody know haw I can generate an 8bit dac waveform in LTSpice.
Sine wave would be fine , preferably variable frequency.
I'd like to be able to test different filters that could be used after an 8 bit dac.
I'm trying to avoid actually building a DAC in ltspice , just want the output waveform.
You could probably do it with a ridiculously long PWL file , but that is not really practical.
Cheers
Neddie
If you read the LTspice documentation and think a bit, you'll figure out how to implement a quantizer in behavioral code.
Hint: there are round(), floor() and ceil() functions available. You can implement effectively any digital signal processing algorithm in PSpice or LTspice.
