Ricewind
Newbie level 6
Hallo, I am trying to implement a DDS in my Spartan 6. The DDS is: https://www.xilinx.com/support/documentation/ip_documentation/ds794_dds_compiler.pdf
the problem I get is trying to understand which DACs do I need to select in order to use the results of such a DDS in the analog world. I will be using signals until around 100 MHz, so I will need a DAC capable of working at 200 MHz... I have no idea on how do I need to select the DAC. I see in datasheets that they detail a "setting time", which is typically in us margin... much too low.
there must be DACs capable of doing it, as the on-chip DDSs can work until GHz and in an amateur design like: fpga4fun.com - Direct Digital Synthesis (DDS) - Introduction it is so treated.
Can anybody help me with that?
thank you very much in advance
