Hi, after successfully install EN2002 and get it running, I uninstalle the whole xSever pack, because I hated it auto start every time I start Windows.
However, today I checked DA (Design Architecture) and found it can't run. and I am also missing a C:\Nutc directory?
Does it cause DA can't run because there is no xServer?
You should have xserver and Nutc running on your machine for running mentor product in win2000.
you can stop running the xserver and nutc serivce from startup. just .remove these from starup(control panel---/services).
Whenver you want to use en2002 enable these all manually.
I get the same problem on my computer.
I see you've figured it out but I cannot understand your explanation "it was the communication port for the display was blocked i enabled the tcp ip port". Can you please give me some further details.
