bearhuhu
Dear all,
I have a branch in which a resistor is in series with N parallel diode-connected BJTs. However, after the dc analysis, when i annotated the dc node voltage and dc operating points, i found out the current flowing through the resistor was 300nA while the total current flowing through N BJTs was only 200nA. Since the resistor is in series connection with the BJTs, the current flowing through them should be the same. I don't understand why this is happening. Is this because of the leakage, or something else?
Thank you!
Best regards,
Joya
Thank you!
Best regards,
Joya
