Current transformer resolution
gehan_s
Member level 3
Member level 3
Sri Lanka
Hey all,
I need to measure an AC current of 0-6A rms using a CT. I have searched for CTs in the internet and found out that many of them go upto about 30A (some of them higher). If I use one of them (max 30A) will it reduce the resolution of the detected current ?
If so how can I increase the resolution ?(I am thinking of measuring atleast 50mA increments)
Also please tell me how to interface the CT to the PIC
thanks in advance !!!!!!!!!!!!!!!
picgak
Advanced Member level 1
connect CT to a precision rectifier using opamp and use a amplifying stage using opamp so that the maximum v is within 5v dc use a zenr for protecting the pic input
Tahmid
Advanced Member level 6
Silicon Valley, California, USA (from Dhaka, Bangl
Use a load resistor at the output of the current transformer.
Here's one way you can interface the current transformer:
madhusuthanan
Full Member level 3
Full Member level 3
madurai
use a burdon resistor llel to CT. then you use precision rectifier signal, it's o/p range is max of 5v. then o/p given to the adc i/p of the pic microcontrller.
klystron
South Africa
Use multiple primary turns (loop your load current wire multiple times through the CT). This will improve the CT resolution.
babatundeawe
Full Member level 5
Full Member level 5
Nigeria
tried making this circuit but i cudnt get the values stable on my display. when i measured the output i cudnt get a dc outptu except ac output can u or someone explain how to get dc output for interfacing with micro.
secondly the output is very low in the range of millivolt, i know i can amplify it but the output is still oscilating please help
gehan_s
Member level 3
Member level 3
Sri Lanka
Hi babatundeawe,
Well you are measuring a AC current. So it must vary with time. When you sample the voltage what you are getting is instantaneous values.
Regards
babatundeawe
Full Member level 5
Full Member level 5
Nigeria
thanks gehan. for ur resonse
please can you expantiate further especially how i can use the instantenous voltage to calculate the current and how can i use microcontroller adc to get these values
thankss
picgak
thankss
the output of the CT can be bridge rectified and filtered for a stable reading
babatundeawe
Full Member level 5
Full Member level 5
Nigeria
considering forward voltage of rectifying diode and the voltage output level (in mV)of CT's its difficult to rectify and get an output. i ve tried different precision rectifier found on this site but none is giving me a pure dc output. please what do u advice
madhusuthanan
Full Member level 3
Full Member level 3
madurai
hi,
the output of the CT should be precison rectifier & reading si read in microcontroller.
this is useful link in eada board
https://www.edaboard.com/threads/265127/
